F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Aftermarket
Thread Tools Display Modes
Old 05-20-2009, 03:30 PM
Vehicle: 2003 Ford F150
E-fan tip
I've noticed that one of the biggest complaints about an e-fan install is shroud removal. If you drain the radiator down to just below the top hose level and remove the top radiator hose from the rad and bend it back out of the way, you can lift the shroud and fan straight up and out. It will help prevent marring the fins or worse, dropping the fan and really messing up your radiator.
Bob
2003 F150 XLT SPORT 4X4
5.4 , AUTO.
TROYER ELECTRIC FANS
K&N AIR FILTER
CAT BACK SIDO EXHAUST
TRIFECTA TONNEAU
ELEC.TAILGATE LOCK
GOTT'S INTAKE MOD
40,000 MILES AND SLOWLY CLIMBING
Old 06-23-2009, 02:23 PM
Vehicle: 1999 Ford F 150
whats the gotts intake mod? PI intake?
99' F 150 4.6 swapped 2002 5.4 and trans.
Pacesetter lth's to Magnaflow hi-flow cats, UD pulleys w/ gatorbelt, e-fans,ac bypass pulley, 9mm wires & MSD coilpacks, K&N air intake, EDGE EVO, Stage 2 Comp Cams and ported heads, Comp Cams behive valve springs, 3inch body lift w/ 35" BFG Mud Terrains on black Cregger steal rims and Eaton Posi-Unit 3.55 gears.
Old 06-23-2009, 02:44 PM
Vehicle: 1998 Ford F-150
Send a message via AIM to Raptor05121 Send a message via MSN to Raptor05121 Send a message via Yahoo to Raptor05121
my shroud came out without a hitch. my tip is to have another pair of hands there and remove the fan and shroud at the same time
4.2L V6 - M5OD | 16" Dual Efans | 2" Drop Shackles | K&N Series-77 | Port & Polish TB
Bent Frame Mod | Custom Down-Turned Bumper | Accordian-style bed flooring
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
