F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Aftermarket
Thread Tools Display Modes
Old 03-13-2009, 04:40 PM
Vehicle: 2004 Ford F150
Troyer eFans - ORDERED
Just ordered my Troyer eFans! Super excited, will photograph the install for everyone.
Specs: 2004 4.6L SCAB | Gryphon Programmer 87 Performance | Magnaflow True Dual Exhaust - Rear Cat Delete | S&B CAI | Summit Underdrive Pulleys | Troyer eFans (ordered) | Smittybilt Bullbar | Procomp 6" Driving Lights | UWS Toolbox | Rhino Lining | Chrome Steprails | 2.5" Leveling Kit | 265/70/R17 Goodyear Wrangler AT's
Vids: Magnaflow True Duals w/ High Flow Cats - Magnaflow Duals without Rear Cats - Interior Exhaust Sound 1
Old 03-13-2009, 05:19 PM
Vehicle: 2003 Ford F150 FX4
I am looking at these too. Do you know if Troyer and Flex-A-Lite have solved the issue with their controllers melting yet? From what I have read here the only controllers without issues so far are the DC Controllers. Any thoughts?
Old 03-13-2009, 06:44 PM
I hadn't heard anything about melting controllers. I dare mine to melt.
Old 03-16-2009, 12:05 PM
Quote:
From what I have seen mounting location definately plays a part. They seem to need to be kept cool and for the most part dry. I think the two popular locations are behind the headlight and right on the battery cover. One guy (I forget who, sorry) put his inside the cab under the dash. I thought that was a good idea too. A little extra wiring but it would be cool and dry.
I would be interested to hear what you think of the kit when you get it and how the installation goes.
Old 03-16-2009, 04:39 PM
Quote:
Will do! Planning to photo document the install and will post when complete!
Old 03-16-2009, 11:42 PM
Vehicle: 2004 Ford F150 FX4
awesome Im looking to do the same kit soon... is your truck a 5.4?
Old 03-17-2009, 09:48 AM
No, I've got the 4.6L
Old 03-17-2009, 11:47 AM
8up 8up is offline
Vehicle: 2006 Ford F150
I'v got that same kit setting in the garage wating for nicer weather to install. like the idia of mounting the controllers inside the cab. looking forward the seeing your pic's.
Old 03-18-2009, 12:38 PM
Vehicle: 2000 Ford F150
Troyer Efans
I had my fans since 2003 on my f-150,and yes my controllers went bad, changed them out last year, they work great!
2000 F-150 scab 5.4
superchip behind cpu
Airaid since 2000
magaflow siso 3 inch catback
swaybar on rear
E-fans from troyer
sfi undrive pullys
75mm bbk
OBX long tube headers!!
**** Cepek DC-1 17x9
BFG 285-70-17
lowered two inches in rear
15.66 at 88.78 mph best time for now!
Time for upgrades!
Old 03-18-2009, 12:46 PM
Quote:
Did the new set of controllers look like they had been improved over the old ones or did you change them out with another brand?
Old 03-19-2009, 05:22 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
I have had to replace 1 controller in 6 years of use. I have had my engine bay coated in mud many times. Here is how mine are mounted. The Zip tie runs through one of the controller mounting holes and they hang there out of harm's way.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 03-20-2009, 11:04 AM
Quote:
Thanks JMC. I just want to be sure that this mod isn't going to leave me stranded when I am towing the trailer or hauling my quad. When I did a "search" on this I read a lot of people talking about melting controllers so now I'm paranoid.
Old 03-20-2009, 11:35 AM
Vehicle: 2007 Ford F150
Send a message via MSN to mana_f150 Send a message via Yahoo to mana_f150
am keeping an eye on this thread
Old 03-20-2009, 01:51 PM
JMC JMC is offline
I have 3 switches on my overhead console. One is to turn both fans off for water crossings. The other two individually turn on the fans. I also have a jumper wire that I can use to short the controllers to turn on the fans. The only way I can be stranded is if the motors burn out. Besides with Failsafe cooling you can drive for quite a distance.
Regards
Jean Marc Chartier
Old 03-20-2009, 02:13 PM
Troyer Fans
I've been running Troyer fans on my truck here in the Northern Arizona desert for about a year and a half and have had zero cooling problems. They work as advertised. I did have one controller fail about 8 months after install and they promptly replaced it. I do have to put in my 2 cents here about a few things concerning the install. Troyer furnishes an electrical kit with switches, connectors, etc. I chose not to use the butt connectors because I believe that causes most of the meltdown issues due to poor connections. These fans pull alot of juice and a poor connection is not going to cut it. I soldered ALL connections and haven't had a bit of problems. Then use shrink tube over the soldered joints. Also, unless they changed them, the instructions tell you to put the temp probes near the inlet hose. I put mine in the top center of the radiator between the fans. I called Troyer and they said that's where they put them now. It keeps the fans from cycling too much. One more thing. The instructions say when setting the controllers with a point and shoot thermometer, to point it at the probe. They told me to now point it at the nearest radiator tube, not the fin. I think these fans are worth every dime and would highly recommend them. Good luck.
Bob
2003 F150 XLT SPORT 4X4
5.4 , AUTO.
TROYER ELECTRIC FANS
K&N AIR FILTER
CAT BACK SIDO EXHAUST
TRIFECTA TONNEAU
ELEC.TAILGATE LOCK
GOTT'S INTAKE MOD
40,000 MILES AND SLOWLY CLIMBING
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
