F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Aftermarket
Thread Tools Display Modes
  #106
Old 04-08-2008, 01:17 AM
Vehicle: 2005 Ford F150 5.4
Smile
Quote:
Originally Posted by Big Slick
Lenore,
I think you sold me on the Lincoln fan and the FK35. I want to know one thing though. you said you extended the fan shround on the lincoln fan around 6 inches i think (can't find the post). question is, how did you go about doing that? what's the process? thanks.
You know I did it with a shroud off an old Ford straight six that I found in the junk yard. personally, I wouldnt botther again. the Shroud that come on the Lincoln/Thunderbird is a nice square shape and adding some baffles on either side of the lincoln shroud to close off the gap to the radiator would be the best way... I did that exact thing on my shroud on the left side of the radiator. I still love my mounting brackets and considered making the darn things with instructions to sell to potential interested folks that want to mount the lincoln fan to the F150. I only have two screws holding the whole shroud to the radiator, with no rods going through the fins etc. I will try to take some pictures so you can see it. My upper brackets are in my photos.
The shroud on the Lincoln/thunderbird is easy to make brakets for and either pop rivet them on as I did or use traditional screws and nuts. Mounting the shroud essentially in the middle of the radiator from left to right should be quite sufficient for cooling, heck the darn thing never comes on except when the air conditioning is selected or you are in heavy, hot, stop and go traffic. back to your original questions I used a fiberglass kit from Walmart and part of this other junk shroud and abasically put the two shrouds together on the right side of the radiator. But I wouldnt bother. The Fan is 18inches and the original fan is only 19 inches and the lincoln shroud covers over 75% of the radiator. If you look at my last picture of the gallery under e fans and look closely you will see the extension baffle that reaches the radiator coils. It was some plastic from lawn edging that I had laying around and I painted it black and pop riveted it to the lincoln shroud. This essentially cause the fan to suck all air through the raidiator instead of through the gap that would have been there.
  #107
Old 04-08-2008, 09:16 AM
thanks lenore,
if you think it's not necessary, i'll probably just mount the fan in the middle like you said and see if it's worth the trouble later on to extend the shroud. if you think about it, everyone else who runs dual fans, with the exception of the flex a lites', don't have ANY shroud.
i like your mounting brackets and will probably emulate them. did you use off the shelf parts, or fab the metal yourself? any special tools? i have all kinds of hand tools, but nothing but a vice and a hammer to shape metal.
  #108
Old 04-08-2008, 10:01 AM
btw, is this the same fan?
http://cgi.ebay.com/ebaymotors/Linco...em180229722662
i'm a little confused when looking for the lincoln fan. some ads say that the later model mark viii's used the 4300cfm fan and that the earlier models, didn't have the same output.
  #109
Old 04-08-2008, 11:38 AM
that is what the fan looks like, I got mine at a local u pull it. Look at the v-8 powered later model thunderbirds, they have that fan. The blades measure 18 inch and make sure to cut the harness back in the car to give yourself some wire to work with. I welded the upper brackets to wrap over the top of the radiator.
  #110
Old 04-08-2008, 12:44 PM
cool. fk35 does the trick with this fan?
  #111
Old 04-08-2008, 01:35 PM
Vehicle: 2003 Ford Expedition
I thought they pulled 42 amps? Granted, that would be when at full speed.
I got the 50P running mine. BTW, I have one of the two speed fans. Hooked up the blue wire since that's the high speed one.
Got it from this guy. Since he lived close by, I picked it up and didn't have to pay shipping.
EDIT: Yea, I'm too lazy to go to the junkyard and pay 30 for one (seems to be the going rate for them).
2003 Expedition XLT 4.6 V8
AFE CAI
Custom Sniper Tune by Matt
Swapped Maggy 18" Muffler
Summit underdrive pulleys
  #112
Old 04-08-2008, 02:36 PM
what was your search criteria you entered? I enter "lincoln mark viii fan" and i've never seen that one.
this is the cfm/amperage graph for the 18" fan on DC Controls' website:
  #113
Old 04-08-2008, 03:16 PM
I just did "Mark VIII fan".
AFE CAI
  #114
Old 04-08-2008, 05:33 PM
Yes, and according to Brian, He sells the 18 inch fan and the FK35 together. But the junk yard is a lot cheaper, By the way look at my pictures for the source of ignition source for hooking up the controller, the plug I went into on the firewall on the right side of the engine compartment has a red with yellow stripe wire that is switched when the truck is turned on. As for the AC connnection I went right down to the harness on the compressor. The black wire is ground and the other wire is 12v switched on when the compressor runs.
  #115
Old 04-08-2008, 07:16 PM
thanks again man. what sort of connectors did you use to make your connections? i know a lot of people use the blue clamp-style connectors, but i was a completely clean, factory looking install.
  #116
Old 04-08-2008, 08:51 PM
I used the clamp style on the AC and IGnition connections, Bought some of that corrogated sleeving to cover all wires and protect from damage. The controller comes with all connectors for the fan, and battery connections. I have a professional crimping tool (my past career was 38years of electronics) so my crimps are excellent and with the type of current draws you can get at 12v you want very good connections. The highest failure rate is do to bad connections in automotive wiring. I dont know what your skill level is in this area. Take your time, do it right, and it will work well for you.
  #117
Old 04-09-2008, 09:13 AM
i have some experience with electronics and soldering and would solder and heat shrink all my connections. i'm well aware of problems with current and poor connections and it's not something i'm willing to risk on my daily driver.
  #118
Old 04-09-2008, 10:04 AM
sorry lenore, one last thing:
when you pulled the fan from the junkyard, what tools were necessary? i'm going to go today to look for one, but don't want to lug my whole tool chest down there.
  #119
Old 04-09-2008, 11:20 AM
A small socket set I cant remember the size of the bolts, 8mm, 10mm, sorry but just carry a small range, and a large pair of dikes to cut the wiring harness back about a foot or so from the plug on the fan. The wire is like a 8 to 10 guage. And by the way soldering, great, with heat shrink.
  #120
Old 04-09-2008, 10:11 PM
Vehicle: 2004 Ford F150 5.4L
If you have the rubber fuse holders I would also recommend dielectric grease. I have melted two of them in two 1/2 years and two days ago melted the third and last. I removed the EFans last night and returned to stock.
If this is your daily driver I would highly recommend thinking twice.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
