F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Special Interest > News & Inside Information
Thread Tools Display Modes
Old 09-25-2009, 10:14 AM
F150online
Administrator
Vehicle: 2005 F-150 King Ranch
All New 6.2 Liter Gasoline Engine Compliments 2011 Ford Super Duty
DALLAS, Sept. 24, 2009 – An all-new 6.2-liter V-8 gasoline engine, which has its roots in Ford Racing powerplants, joins the lineup for the 2011 Ford F-Series Super Duty.
“Our all-new 6.2-liter V-8 engine uses reliable components and proven technology that has been optimized for the high performance and efficiency that our Super Duty customers demand,” said Mike Harrison, Ford V-8 engine programs manager. “It delivers not only significantly better torque and horsepower than the outgoing engine, but also improved fuel economy.”
Core to the improvements is the adoption of an all-new engine ar****ecture, with increased bore spacing, that allows better engine “breathing” in both the intake and exhaust for more power and more overall efficiency.
A closer look at how the new engine achieves its performance:
-Large bore, shorter stroke: This approach to creating power has its roots in storied Ford racing engines from the past. The large bore (102 mm) allows for larger intake and exhaust valves for improved engine breathing, and the short stroke (95 mm) allows higher engine speed for increased horsepower. Still, peak horsepower is generated at a relatively modest 5,500 rpm.
-SOHC valvetrain with roller-rocker shafts: The single overhead camshaft (SOHC) per cylinder head design results in a stiff valvetrain that allows optimized camshaft lift profiles and helps produce great low-speed torque. The roller-rocker shafts allow valve angles to be splayed, resulting in optimized intake and exhaust port layout for better breathing.
-Dual-equal variable cam timing: Intake and exhaust valve opening and closing events are phased at the same time to optimize fuel economy and performance throughout the engine speed range and throttle positions.
-Two spark plugs per cylinder: Because of the large bore size, two spark plugs per cylinder are used to more efficiently burn the fuel-air mixture in the combustion chamber, enabling better fuel economy and increased engine torque. The twin plugs also help the engine maintain a smooth, stable idle.
-Dual knock sensors: A knock sensor on each bank of cylinders of the V-8 engine allows the spark timing of each of the cylinders to be individually optimized real time, throughout the engine speed range. The engine continuously monitors engine performance and applies this real-time learning to optimize timing via an adaptive algorithm.
-Better engine crankcase “breathing” and efficiency: Significant development work and computer-aided engineering optimized the cylinder block for more efficient airflow in the crankcase as the pistons move up and down in the bores, resulting in improved torque at higher engine speeds. Piston-cooling jets squirt oil on the underside of the pistons to keep the piston crowns cool under extreme operating conditions. The cooling jets also allow for a higher compression ratio for better engine efficiency and faster engine oil warm-up on cold starts, also improving fuel economy.
Key features of the new 6.2-liter V-8 gasoline engine include:
-Cast-iron engine block and four-bolt main bearing caps, with cross bolts, for durability
-Aluminum cylinder heads, with two valves per cylinder and two spark plugs per cylinder
-Cast-iron crankshaft, with dual-mode damper
-Forged steel connecting rods
-Cast-aluminum pistons, with cooling jets
-Single overhead camshaft with variable valve timing and roller-rocker shaft valvetrain
-Magnesium cam covers for lighter weight
-Stamped-steel oil pan
-Composite intake manifold
-Stainless-steel fuel rail; port-fuel-injected; mechanical returnless fuel system
9.8:1 compression ratio
-E85/flex fuel capable
-Performance heritage with proven durability and reliability
The concept of using a large-bore engine to make horsepower is part of Ford’s DNA, especially its racing heritage – the famous Ford Boss 302 and 351 engines, for example, pioneered many of the same concepts. Several racing projects proved out the performance, durability and flexibility of the new 6.2-liter V-8 engine ar****ecture.
Among the racing-themed highlights that contributed to the engine’s development:
A 7.0-liter version running on E85 fuel produced 800 horsepower in a winning Mustang drag racing application driven by Don Bowles
A specially calibrated production-based 6.2-liter engine achieved 500 horsepower and ran flawlessly in the Ford F-150 SVT Raptor R race truck in the 2008 Baja 1000
Testing on the 6.2-liter V-8 included running multiple engines for more than 500 hours at peak torque and peak horsepower as well as customer-correlated 1,000-hour road load tests to ensure dependability for even the toughest Ford F-Series Super Duty customer.
All told, more than 50 engines were put through the dynamometer lab, running a variety of durability and development tests, undergoing extremes far harsher than can be expected – or duplicated – in the real world. Testing also included high-speed durability, crankshaft-torsional evaluation and engine thermal cycling where the running engine is “shocked” from one coolant temperature extreme to the other.
“From the first test on the dynamometer, this engine was very reliable,” said Bob DeBona, supervisor, Engine Performance and Development. “The precision that went into the engineering and manufacturing of this engine led to very few tweaks to the block during development. Components such as the crank, connecting rods, heads and intake manifold stayed essentially the same throughout our durability testing, which is a testament to the reliability of this new engine. It’s able to pound out the torque, hour after hour, week after week, demonstrating extreme durability.”
The new 6.2-liter V-8 gasoline engine will be built at the Romeo (Michigan) Engine Plant.
Old 09-27-2009, 08:30 AM
Vehicle: 2004 Ford F150
This sounds very promising..........
Hopefully the plug issues won't exist.
With 16 plugs to replace it will not be cheap even doing the yourself.
Didn't Ford already try dual plugs, back in the 80's on a Ranger engine?
MB
Old 09-28-2009, 03:47 AM
Vehicle: 1997 Ford F150
my 97 2.3L ranger had dual plugs.....seemed to work out pretty good.
Old 09-28-2009, 10:55 AM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Duel plugs are just a start. Later I would expect an injector to replace one of the plugs.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
