08 ford F150 nav wire harness
Ok! here is what I got from search: (2008 Ford F150 Wire Harness color code)
Yellow ------- Battery
Red ----------ACC
Black --------Ground
Orange/White ----- ILL
Orange/Black ------ dimmer Ground (Don't know where to in f90BT)
Light Blue -------Power Antenna
Pink ----------Mute (Don't know where to in f90bt)
the pink in f90bt is: car speed signal input.
White -------- FL Speaker (+)
White/Black ---FL Speaker (-)
Gray ----------FR Speaker (+)
Gray/Black ----FR Speaker (-)
Green ---------RL Speaker (+)
Green/Black ---RL Speaker (-)
Violet ---------RR Speaker (+)
Violet/Black --- RR Speaker (-)
I also need help with: 4 Brown cables on harness. (they're all mark as mute. Don't know where to on f90bt)
Any help please!!!
Red ----------ACC
Any help please!!!
One more question?
how about the violet/white from the avic harness? It is for reverse gear signal input.
According to the manual: "This is connected so that the navigation system can detect whether the vehicle is moving forwards or backwards."
where should i connect it? It is necessary?
thank you!
thank you!
One more question?
thank you!
thank you!
