What type transmission fluid to use?
Old 05-16-2002, 08:58 PM
ForesVt's Avatar
Thanks for the info guys & gals?
Wrongdayj is right, the "red NIAGRA" is no fun! Punched a hole and drained the pan, but still makes a big mess when you take the pan off. Beware...
FT valve body, 4x4 pan with drain plug, the right fluid & 1-hour =
If you haven't got the FT valve body yet; no excuses, GET IT!
Thanks Factory_Tech (Greg Evans) & PSP (Lisa).
ForesVt
Old 03-30-2017, 07:06 AM
Andrew Gibbs's Avatar
Bro you are dumb as a box of rocks. Mercon V is what you are supposed to use.
Originally Posted by WrongdayJ
You want the Dextron III/Mercon fluid. They put both names on the bottle because the fluid meets both specifications. If you want a bottle that only says 'Mercon' on it, then you have to go to a Ford dealer and buy Ford Mercon from them direct. Anywhere else you go, it's called Dextron III/Mercon.
Make sure your bottles don't say Mercon V. And don't use a fluid that says it meets both Mercon and Mercon V specification.
(That comes directly from Matt at SVT)
If you can get it in your area, try to get Castrol. It seems to be the only fluid I've found that prominently displays the Ford specification(s) that their fluid meets or exceeds. I'm sure that the other brands meet the same specs, but I kinda feel safer knowing that they are aware enough of the specifications to display that their fluids are in compliance.
Oh, and while you're at the parts store. . .99% of people who have done this service themselves also install a drain-plug while they are in there. The red NIAGRA ain't no fun.
Have fun!!
Mercon V is what the dealership uses dumbass.
Old 03-30-2017, 09:35 AM
glc is offline
They didn't back in 2002 which is when this thread was last active. The 4R100 is a Mercon transmission. The approval to use Mercon V in a 4R100 didn't come till 2007.
http://www.aftermarketnews.com/ford-...or-mercon-atf/
Nice first post, by the way - calling someone a dumbass is no way to win respect and credibility here and bringing up a 15 year old thread just to slam someone is ridiculous.
The following users liked this post:
Old 03-30-2017, 03:40 PM
beechkid's Avatar
Some forums you visit may allow this type of communication, but no matter what your viewpoint, it's not acceptable here.
Old 03-31-2017, 03:28 PM
Struck in AZ's Avatar
Look in the mirror much...solid intro to the forum.
Old 04-10-2017, 02:31 PM
JeffsLightning's Avatar
Where did you go brainiac?
Old 04-10-2017, 07:00 PM
glc is offline
Single post troll.
Old 04-30-2017, 08:42 PM
welcome to reality, thanks for posting and making yourself look an uneducated, untrustworthy individual, while you are aware that almost FIVE years after the post you called out, the information you used was released
so i guess shame on the folks for being in 2002, when it was still 2002
Old 04-30-2017, 10:14 PM
glc is offline
Old 10-25-2017, 08:13 PM
boomercarguy's Avatar
I have a 2005 Ford Escape 3.0 V6 with a CD4E automatic transmission. This first generation, shared with the Mazda Tribute, requires Mercon only -- not Mercon V which was proven to cause damage in that generation. The following generations starting in 2008 used the Mercon V.
I know that this is comparing an orange to an apple but since the 2002 F150 manual transmission took Mercon, can it also take Mercon V without any damage?
I'm getting ready to buy a 2002 F150 with the manual 5-speed and changing fluids is first item on my list.
Old 10-25-2017, 09:53 PM
projectSHO89's Avatar
You're ten years out of date. All applications originally specified to use Mercon were changed to Mercon V ten years ago. Obviously, manuals printed before then could not predict the future.
Old 10-25-2017, 11:27 PM
glc is offline
The manual transmission is not fussy - you can use any ATF or even GM Synchromesh fluid. I use Mobil 1 synthetic ATF in mine.
Old 10-26-2017, 04:05 PM
...or you could use any of the aftermarket fluids that meet the old spec that are still available for anything that originally used Mercon. It's a lot cheaper and more readily available at retail than is Mercon V and its compatibles.
Old 10-26-2017, 09:32 PM
glc is offline
Quick Reply: What type transmission fluid to use?
