I have done research on this and adding 4V heads will add significant power depending on how well the intake was designed. The Navigator heads are not the same as the Cobra. Nor are the Cams. The navigators cams are designed for low end.
The stock lower end and transmission will not hold up. I have not seen BaBolts design and don't know if he is still intending to use the intercooler. I do know that you will need to up the fuel pressure and need dual injectors or you can say by,by, to YOUR intake valves. The right amount of fuel must be added to keep the valves cool and to do it you need two injectors or a single in with a dual out. Like a "Y." Maybe there is one that can spray enough.
This is a big risk for people who can't afford to build the lower end and trans to take the added stress of hp and torque. Same goes for adding a more efficient supercharger. If you are adding an increase of 20-30% more flow, that is significantly higher then a pulley or two. That is going to put more stress on those rods.
If any of you plan on adding supercharger packages that might be available soon. You better aske for copies of durability data for your lawyer. Ford pockets are much deeper then those on here.
They run their engines through extensive testing on dyno's and for many miles on the tracks. How many of the current performance suppliers have hours on an engine running these new packages?
Will it run in cold weather or will you need to keep flashing your chip to work with the changing weather and octain in some states. Do they have the cash to send their development vehicles to Canada or Arizona to make sure their product works in hot and cold environments?
You can show me hp numbers all day. Show me the durability data that says I won't be replacing an engine 1,000 miles later.
Do the people developing these engine parts have engineering degrees?
Do they know engineering theory on combustible engines?
Those of you that are in a hurry to drop your cash down in the name of H.P. may be adding additional cash to get a new engine.
I will wait to do my own, or on a company that has the resources to design and have hours of durability on their product such as eddlebrock or holley. A $3,000 mod can cost you $10,000.
You can say that about any mode. But you didn't pay $3000 for a chip and pulley. Think about it!! You will have no way of hiding a change like that from a dealer if you lose your engine.
