dual fuel pump resistor
I have a 00 lightning and i installed 2 walbro 255's a month ago. now my truck runs like crap. I check my fuel pressure and at idle fuel pressure is at 25-27 psi koeo its at 33 psi. so i check the voltage on my fuel circuit and voltage is at 12v at prime then it goes down to around 3-4v. so I checked my fuel pump resistor and it ohms out at 1.2 ohms. so I've been on this site all day to see what upgrades my lightning brothers were doing and i like the 2 resistors set up with the heat sink. So i bought 2 heat sinks for a few dollars and I'm going to order the fuel pump resistor tonight. My big question is does the dual resistor provide a full 12v to the walbros?? i don't want to do the full fuel system upgrade or jumper the hi low relay but i don't want to shorten the life of the expensive fuel pumps. Another question i have is what is the resistor ohm out at??
Thanks in advance
Thanks in advance
