Plenum Problem
Old Feb 23, 2005 | 03:07 PM
Andy@Chikenears's Avatar
Question Plenum Problem
Hey all!
What would be the best or maybe the easiest way to get the paint off of a stock plenum?
Andy@Chickenears
Old Feb 23, 2005 | 03:27 PM
m springer's Avatar
"Aircraft Stripper" available at Home Depot - is some mean stuff - I have used that to strip cars. It is fast, aggressive, and reasonably easy to clean up.
(It says water cleans it up, but we always wiped with laquer thinner to be sure and to not promote rust on a steel body.)
Also, it dries hard, so disposal is not a problem (not hazardous)
Alternatively, maybe sandblasting?
Old Feb 23, 2005 | 03:28 PM
Black 2000's Avatar
Naval Jelly
spray it, let it soak, scrape a little of the thicker spots and then repeat.
Later...
Bruce
Old Feb 23, 2005 | 03:49 PM
Thanks , I'm trying to get away from sandblasting.
I'll give those a shot. Where can you get naval jelly?
Andy@Chickenears
Old Feb 23, 2005 | 03:55 PM
Bootbox's Avatar
Any auto parts store, AutoZone etc...
Old Feb 23, 2005 | 04:19 PM
fullboogie's Avatar
Naval jelly is for protecting against rust. The aircraft stripper would work, but why not bead blasting? Leaves a nice finish, then you can clear coat it.
Old Feb 23, 2005 | 05:31 PM
m springer's Avatar
I believe that the "Aircradt Stripper" will be much more aggressive than the Navel Jelly.
Buy a few cheap disposable paint brushes (horsehair, not nylon), along with the stripper.
Also, you will need some sort of metal or ceramic bowl (stripper will eat most plastics)
Shake up the stripper in the can, then open carefully (keep face away, the fumes are nasty)
pour stripper in a bowl, and apply to the part with a brush. Put on a thick coat, and let it sit. If you are in a colder climate, or humid/damp, use a portable heatlight to accellerate the process.
The paint should bubble up, or if laquer will liquify. You can use a bondo scraper or other similar instrument to scrape off the stripper, then wash with water, and/or laquer thinner to neutralize the stripper.
Do all this on newspapers or some sort of disposable material, then throw it away. Do not leave drops of stripper on the floor or other objects, as it will burn your skin later on if you touch it. Also, you do not want to step in it, and then transfer it into a car or (gasp) the lightning floormats...!!!
ps - wash the bowl and brush with water. If you wash the brush, you should be able to re-use it a time or two, just don't paint with it...
Old Feb 28, 2005 | 03:40 PM
Thanks for the help M Springer. I bought what I thought was aircraft stripper at home depot . I'm not sure it is the right stuff, it did not work at all . Here's a pic of the can. Does this look like the right stuff?
Andy@Chickenears [IMG][/IMG]
Old Feb 28, 2005 | 04:16 PM
HIHOAG's Avatar
Get a paint stripper with NMP(N-Methylpyrrolidone) in the ingredients.
Old Feb 28, 2005 | 04:28 PM
Her2001's Avatar
I used the same stuff. After letting it sit for 20 minutes it pulled the coating right off. I scrubbed it a little with a scotch pad.
Old Feb 28, 2005 | 06:13 PM
olefafl's Avatar
What are you doing?
I used a 3-M lock disk to remove the paint where I was going to weld mine.
