Jack Points?
Jack Points?
Is there any specific jack point on our trucks. I got a flat on the front drivers side on the way to my buddys shop earlier today. We left it there for a while and went out (cant let a flat ruin your sat night )then came back around 2:45 to fix it. It was dark and kinda hard to see but I tried to get the jack under there on the frame. At first I just put it on the frame right under where the bed and cab meet. There were some noises when I lifted it so I stopped. I moved the jack up to what seemed like a stiffer part of the frame, right before the frame slopes up behind the front wheels. This place wasnt too sturdy either but by that time it was 3 am and I wanted to get home. Is there any certain place to jack up the truck from the side?? In the back I do it on the pumpkin even though it says not to and in the front I just go on the cross member. But the sides....?
Originally posted by lightning1291
how about jacking it up by the pumpkin
If you look to the right you can just see one of the jack stands that are holding up the rear end while we change the shocks. The jack was placed under the pumkin as an added safety while I worked under the truck. It was JUST holding the weight of the rear end. It wasnt jacked up using the pumpkin.
Thanks for your concern about my truck though.... LOL
Doug
How are you using Central Florida road runner broadband in Texas ?
did i say i lived in texas home is right around the corner from you doug.... oh yea, i CAN utilize the cfl system when i am home visiting family, and you my friend would be none the wiser... there is still no broadband in small town TX
Im not sure if its the water or the education system....
