F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Interior Care
Interior Care SPONSORED BY:
Thread Tools Display Modes
Old 09-24-2001, 06:17 PM
Vehicle: 2000
Irritating DASH RATTLE!
I seriously cant take rattle any longer, I MUST fix it! The passenger side dash nearing the windshield is where I narrowed it down to. Even when I push on the dash, it still does it, so I know its underneath.
Any ideas?
Old 09-24-2001, 06:23 PM
dlf dlf is offline
Vehicle: 2001 Ford F-150
Send a message via Yahoo to dlf
Is it the airbag cover on the top of the dash, not the front facing the passenger seat, but the oval shaped tray on top? My friend's '98 F- 150 STX rattles in that spot at times..... thanks to those smooth Pasadena, TX roads......
-'01 4x2 SCREW
-4.6L Triton V-8
-Oxford White w/ Med. Graphite Cloth
-Captain's chairs
Added stuff:
-TOFF Spray-in Bed liner
-ARE LSII Bed Cover
-K&N Drop in Air Filter
-70 Series Flowmaster w/ 3 1/2" Tailpipe
-Drawtite Receiver Hitch w/ Red, White & Blue Shield w/ Eagle head cover
-Westin Nerf bars (Chrome)
-Ventshade smoke colored bug shield
- Lightning Headlights, Corners & Tails
- Pioneer TS-A6865 3-way Speakers Front and Rear.
- Clarion Camoflauge "Powered Subwoofer"
- MGWLTD.COM Triple Chrome A/C, AOD, Turn Signal and Tilt Wheel Knobs
- '01 Harley Grill
- White Ford ovals (front and rear)
Wish List:
- Color-matched tail-gate handle
- 17" Wheels
- Aftermarket Head Unit
- XM radio (waiting to see if they develop the internal tuners/ receivers)
Old 09-24-2001, 07:31 PM
Vehicle: 2000
Ill check on that.
I need some help on fixing this.
Im thinking of just going to the dealer, after all, the dash rattles, the supercab door rattles, the engine had blue smoke and idles high..
Old 09-24-2001, 08:57 PM
Vehicle: 2000 Ford F150
I notice a small rattle when the HVAC fan is on but it isn't too bad. I figured the fan is not perfectly balanced and there isn't much that can be done to remedy it. Rule of thumb, if you take the dash apart you might introduce more rattles when you put it back together.
Old 09-24-2001, 09:07 PM
Vehicle: 1999 Ford F150
I'll second the tray on top of the right side dash (the one that has the little vent on top for the headlight sensors). Mine buzzes and vibrates, then I slap first thing the morning and it seems to be okay the rest of the day. I'll have a dealer look at it beacause I don't know if it's the plastick piece, or the sensor that is loose.
'99 Lariat XCab.
Old 09-24-2001, 09:18 PM
Check the door panel on the passenger side. I had some rattling there (I thought it was from the dashboard) but after I had the front speakers replaced, the noise disappeared The installers must have tightened something in the door.
-boarder
2001 F-150 4x4 Flareside.
Old 09-25-2001, 12:05 PM
I have finally figured out what mine is, and it might be yours too. The bottom of the door panel makes slight contact with the plastic trim below it on the floor. When the temperature's cooler, it rubs and makes noise which seems to radiate up to the dash. When it's warmer, I think the plastic expands just enough that the two pieces are jammed tight enough together not to move with every bump in the road. However, since the floor trim is all the way down, and the door panel is as far up as I can get it, I think the only permanent solution is to raise the door slightly on the hinges. That's the kind of job where I always end up making things worse, so I probably won't be doing that!
Hope that helps.
Scott
Old 09-27-2001, 05:04 PM
I've had the same annoying rattle. Mine is near the airbag. I took it to the dealer because it was getting on my nerves. The fella told me he tightened up everything in the dash, took it on a drive, and had no problems. I said great. Picked it up, a mile later, rattle. My wife was with me and I exclaimed "hit that!" She hit the dash and it stopped. However, it keeps coming back periodically. The beer is on me for whoever can stop that infernal rattling.
Old 09-29-2001, 03:31 AM
Vehicle: 1997 Ford F150
Rattling sound could be the radio harness - I had my fixed.
Old 10-06-2001, 05:26 PM
Vehicle: 2000
Quote:
-boarder
Theres one there, especially if the passenger has their elbow on the panel.
Old 10-06-2001, 05:28 PM
Vehicle: 2000
Quote:
What do you mean by radio harness?
Old 11-03-2001, 03:25 PM
Vehicle: 2000
bump
Old 11-05-2001, 05:24 PM
Vehicle: 2001 ford F150
Dash rattle found
I have finally found it. The rattle is most likely a relay switch that is laying loose on top of your radio box. when you go over a bump it rattles. The sensor is supposed to be held in place by a steel clip that is slids onto. Take your dash apart and you will find it laying loose off of the clip. I imagine that it got detached during dash installation. the rattle sounds like it is coming from the headlight sensor area, but it actually righ by it on top of the plastic radio box.
Hope this helps. Email me if you have questions.
chuck
Old 11-08-2001, 07:26 PM
My dash used to rattle the same way until one day while driving slow I open the door to spit and wala, the rattle was gone! Close the door and the rattle was back! I noticed there is a slight gap in between the door panel and the end of the dashboard. As the car flexes when moving the two plastic parts rub and hit. This causes an irritating rattle!
Solution: I went to the hardware store and bought these appliance-sliding pads that you put on the bottom of appliances or furniture so they can slide on the floor easily. They are about twice the size of a quarter and they have sticky backs to hold them in place. I stuck one on the door and one on the dash so when the door is shut the guides rub against each other. No more rattle! And you barely notice them only when the door is open.
Old 11-29-2001, 05:30 PM
Vehicle: 2000
Re: Dash rattle found
Thanks!
Do you mean the oval piece? I removed it (3rd time LOL) and tie strapped EVERYthing down and put foam so it wont even touch the dash.
Ill see how it goes.
chuck
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
