Swap 2013 buckets and rear bench into 2001 supercrew?
I'm just spit-balling an answer here, but...
-If you measured to be sure they will physically fit in the space available.
-If you have a reasonable amount of wiring and fabricating knowledge to adapt the mounting hardware and any wiring associated with the seats.
...there is no reason you shouldn't be able to make them work in your truck. My only concern would be your seat belts. In my 2003 they are integrated into the seats themselves, are they in the 2013 seats as well? If not you will need to find an alternative, because they're required by law
