2002 F150 Door Armrest Plastic Broken.....
Old 09-17-2014, 07:44 PM
ag-ford-4x4's Avatar
In the door panels on the 2002 F150 Super Crew, there is a white plastic brace piece that bolts/screws to the door. It is attached to the armrest part. Can this piece be replaced? Where do I get it?
Old 12-15-2014, 10:22 PM
icegta89's Avatar
broken plastic
I have the same problem. Just wondering if you found an answer to your question.
Old 12-24-2014, 01:45 AM
01 gt f150's Avatar
Do you need it because the tab broke off where the screw goes? If you have the other piece a paint and body shop supplier will have the epoxy to fix it. Mine was glued 2 years ago and still holding.
Old 12-30-2014, 01:14 AM
I used pc7 epoxy. No idea if it's still holding. I molded it on and let it cure and reinstalled.
Quick Reply: 2002 F150 Door Armrest Plastic Broken.....
