shift knobs
Old May 1, 2011 | 06:55 PM
lightningx54's Avatar
shift *****
Does anyone have a solution to the oem rubber shifts ***** sliding off the sticks? Both my transfercase **** and transmission shift **** keep sliding off. Its worse in the summer because the rubber is softer.
Old May 1, 2011 | 07:47 PM
five0merc's Avatar
Mine on my tranny doesn't coma off at all. If you want I can send you the lever here when I do my swap to a ZF6 in the next couple months. On the other hand my transfer case shifter has the same problem.
Old May 1, 2011 | 07:48 PM
zf6? EDIT: nevermind i googled it
Old May 1, 2011 | 07:59 PM
five0merc's Avatar
Haha yea. SUperduty 6 speed. Gonna need something to handle the power from the supercharged 5.4 I am building.
Old May 1, 2011 | 08:03 PM
nice dude.
Old Oct 2, 2011 | 11:20 PM
Flamed02's Avatar
I know this is an old thread but in case you haven't found your solution, you can use a tap and dye set to cut threads onto your shift lever, and then you can use a threaded shift **** of your choice.
