looks good, but i got a feeling it won't wear very good. my dash and interior parts where painted and infared cured for good measure, maybe you'll have good luck
i just used krylon fusion for plastics. i think it turned out really good. i jsut gotta wait then add the clear coat and ill be good. in my opinion though i wouldnt have gone with the gloss black though bc when the sun hits it its too shiny and makes it tough to see. but other than that i love it. and ya ill try to get better pics tomorrow. waited a bit too long to do it
hey man, i was planning on doing this too, you are saying you used krylon gloss black for the whole thing? i wonder what you used to paint the area above the glove compartment(where the airbag is at) and the rubbery area around the dash. if you used krylon on that isnt the handle to close the door and steering wheel the same material?
So you used Gloss black but its better to go with Satin Black your saying Correct so it doesnt have that much shine? What kinda prep work did you do besides masking things off (Sanding ne thing or no)? Also did you remove anything to paint it then put it back in or was everything masked off with newspaper
Edit: How is it holding up after that you have done it? Ne thing starting to peel or come off in certain areas or no? How many coats did you do to each part
Ya I would use satin black and the only prep work I did was clean everything with soap and water to get grease and fingerprints off. So far it's holding up good but I need to put a clear coat on it soon
I am in the process of doing this as well...well kind of. Im only wanting to paint the plastics that are on either side of the radio and the end of the dash on both sides and doors. I want to get rid of that dark grey color and leave the light grey. Im going to do a flat black. I have limo tint all around and 30% on the windsheild so I dont think I will get barely any sun reflection off of that. Is it hard or even possible to remove just those dark grey plastic pieces? (I dont want to paint in inside the truck) Also, as for type of paint and prep, I got some high heat flat black..I bought this because I figure if you can paint an engine block and it not chip or peel, maby it won't on my dash...am I correct or wwwaayy wrong lol. Im not much of a follower in the art of spray paints. and prep, I was going to go with just some soap and water..maby even a light rub down of some miracle spirits or thinner first. idk
I have 5% all around my truck and I still get bad reflection. I just used krylon fusion and I left everything in the truck and painted it just bc I couldn't figure out how to get the whole dash out
