F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Interior Care
Interior Care SPONSORED BY:
Thread Tools Display Modes
Old 05-04-2009, 09:59 AM
Vehicle: 2002 Ford F150
Spray foam insulation in doors?
Can you guys think of any problems with spraying foam insulation in the doors for a sound and thermal barrier?
I would probably use low-expanding "great stuff"
...could be a shot in the dark, but I thought I would ask.
Old 05-04-2009, 10:13 AM
Vehicle: 2005 FORD F150
I would think there is a potential for a lot of problems down the road heaven forbid you have to fix something in the door. I would just get a good sound dampener and you will reap the same benefits but you will also be able to get in there and fix things if need be.
2005 F-150 5.4L 3V Supercrew Lariat 4x4
Old 05-04-2009, 11:33 AM
What is the brand of Sound dampener that you use? Dynamat is the most expensive, but reasonable on ebay.
Makes sense about needing to fix the doors.
2002 KR Supercrew 4x4, 5.4l, 55K
22" Magnaflow Cat Back Exhaust, Electric Fans, "DIY" air intake, Xcaliber 3 tuning by Troyer, 35% Window tint, GMS COP's, A believer in Leather CPR
Old 05-04-2009, 11:59 AM
I used Raamatt by Rick at Raamaudio.com It is very reasonably priced and does a good job. It is like $150 (at most after shipping) for 1 roll which is 62.5 sq ft.
Old 05-04-2009, 10:26 PM
Of Course!! Windows!! I can't do this because of the windows. I could however spray in the bottom 1/4 or so until it meets up with the window when it is fully down.
I have taken out my rear seats and most of the trim to install dynamat (or Raammat) and noticed that there are a lot of voids that can be filled in the spray foam. I think that I will probably try this to help with sound barrier. The foam is cheap enough to try it.
I do agree that even with the added step of the spray foam that dynamat is the way to go.
Old 05-05-2009, 11:47 PM
Vehicle: 2004 Ford F150
Doesn’t Ford use a “wet door” design? Check the bottom of your door to see if there are drain holes; there should be one in the front one in the back. Even just coating the bottom up to the window could cover up the drain holes leading to moisture being trapped in the door panel. My thoughts would be sticking to something like Dynamat.
Old 05-05-2009, 11:53 PM
Vehicle: 2008 Ford F150
I dont recommend it, but if you decide to do it, make sure you use open cell, non-structural foam. Closed cell foam will dent your doors!!
Old 05-06-2009, 01:54 AM
Vehicle: 2007 Ford F150,f250
i can see you now. spraying the great stuff in your truck and all the seams busting loose and your panels buckling. spray some in a aluminum coke can and see what happens to it.
Old 05-06-2009, 02:31 AM
Quote:
It takes the easiest route out, it wont buckle anything unless you're using a commercial grade, great stuff is meant for small gaps and windows. I use the stuff daily.
Old 05-16-2009, 03:00 AM
Vehicle: 2006 Ford F150
I seconds the RaamMat from raamaudio.com. I plan to do this within the next couple weeks. Check out the tutorial on the site for how he does the doors. He puts the butyl material on the inside of the door panel and on the inside door panel along with the ensolite (which is like a foam cloth) that deadens road noise.
Old 05-16-2009, 10:27 AM
Vehicle: 1999 Ford F 150
only problem i can imagine would be that your window seals are not sealed. This is true of every vehicle on the road. great stuff is basicly a sponge and inside your doors it has nowhere to drain. eventually you will need new doors as a result.
Old 10-19-2009, 05:21 PM
is it a good idea to use spray foam for the roof and other parts other than the door?
____________________
foam insulation texas
Old 10-19-2009, 05:34 PM
Vehicle: 2009 Ford F150
I am at a loss as to why one would want to do this. Is your truck extremely noisy? Is it hard to warm up the interior?
Yes Ford does use "wet door" technology. I think all mfgr's do.
But what is the purpose for all this extra work and expense?
Old 10-19-2009, 05:41 PM
Try it on your wifes vehicle first and see what happens.
| 2006 XLT 5.4 | 4x4 | 2.5 AS leveling kit | AS AAL | Volant CAI |
| PHP Gryphon Custom Tunes | Dynomax Bullet Dual Exhaust |
| 17x8 XD Spy's +18os| 315/70-17 Goodyear Wrangler Duratracs |
Old 10-19-2009, 06:32 PM
x2 try it on the wifes car and find out if its safe first =D
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
