F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Interior Care
Interior Care SPONSORED BY:
Thread Tools Display Modes
Old 01-03-2009, 08:04 PM
Vehicle: 2004 Ford 150
Okay finally found the pic's
http://s338.photobucket.com/albums/n431/Allenm1000/
Interior leds blue
Sorry it took so long
Old 01-05-2009, 02:32 PM
Old 01-06-2009, 09:30 PM
Vehicle: 2005 Ford F150
Some of those pics are pretty small. I might have missed the thread, but what did you do to make that work? I'd like to do that to my gauges and A/C lights as well.
-Lee
Old 01-06-2009, 09:37 PM
Vehicle: 1997 Ford F150
Send a message via AIM to willys5555 Send a message via Yahoo to willys5555
looks nice...i am trying to change all mine to red right now...i got the a/c switches done and one switch on the door...what did you do to change all the colors? do you have any install pics? i have a 97 so it is a different model but it may be similar. looks good though!
Old 01-06-2009, 09:59 PM
Not hard but time consuming
Unfortunely all of the lights onthe the door, a\c shifter where soldered in place of the green ones.Sometimes it was easy as removin the green led and soldern in the blue.But the shifter was pretty tough,i installed a led under every shift position so the color would be even all the way across.But it's not to hard though,I knew nothing about leds,or solderin but I really wanted the look so I set out to learn on the net all that I needed to know about soldern,resistors,etc.It took me awhile to complete it all do to my work hours but my truck isn;t a daily driver so it was no matter.Just set out to get it done and it turned out pretty good.A word of advise,don't get in a hurry,and if you get convused on how to pop a panel or what is this, the guys on this sit are a wealth of info and I accredit this mod to there help to me.
Old 01-07-2009, 12:09 AM
ok so that is the same way my truck is...on the door switches there is green LEDs...i succesfully did the one switch but the other one i cant get to work...i gave up because i felt my self getting frusterated..i will try again this weekend once i have some time again. did you learn any short cuts or things to be done a certain way to make it easier?
Old 01-07-2009, 07:05 AM
Few things
On the door switches which most of the lights are the doors,I had completely removed the small circuit board from the switch and found the - and + term that comes that gives it illlumination and put two leds in line (with the right polarity)and one resistor of the right size and solderd them in.I'll take a pick of my drivers door switch this week and post it up so that Itt'll help more.
List of must haves (at least I had to have)-
Gun type solden iron(pens are just to dang slow)
small needle nose pliers
Small screw driver for poping switches apart
small side cutter and end cuters(they look like catfish skinners)
Don't drink alot of coffee
Don't get in a hurry
Don't over heat the leds they cant take much
It cool to have a 12v battery on the work place or some way to test them out
Have to know wha size resistor to use in each aplication,1 led, 2led or four each take a differnt size.
Don't buy them from rat shack they are cheaper online (besthongkong or something like that)
3mm work good in small switches,5mm in some places like the shifter,fan speed.
If I get the time I'll try to do a write up or a walk through but it will probaly get buryed under everyone's elses threads
Hope I can help
Old 06-13-2009, 09:03 PM
Vehicle: 2008 Ford F150
allenm100, I'm starting this mod for my truck this month. The only bulb that I have changed so far is the blinking security light in the front of the hood (which wasn't too hard). It was recommended to use a 3mm bulb for that job, but I got away with using a 5mm. My question is since radioshack and local stores don't carry 3mm (only as small as 5mm) can I get away with using 5mm? I probably want to do it by the book and use 3mm, but was just wondering.
To be perfectly honest, since I'm starting this project very soon, I may just have to PM you from time to time if I'm having trouble or need some help. I hope that that's okay with you and if you won't mind helping me if I need it. Thanks a bunch, your truck looks great and I can't wait for mine to look similar!! Keep up the good work!
Old 06-16-2009, 06:37 AM
Stomp the rats!
You could use the 5mm form rat shack but you would come out alot cheaper to go to an online store like superbriteled.com they are way cheaper and briter.Just get like 50 of so of the 3mm, because I promise you,you will mess up alittle!
O and ofcoarse well need pics also
Old 06-18-2009, 11:59 AM
looks good...nice work allen...any new mods on the horizon?
Old 06-20-2009, 01:34 AM
Looks great, a thorough write up would be greatly appreciated.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
