I'd like to replace my center jump seat with an oem center console in my 06. Has anyone done this? If so, how big a deal is it?, and will i be able to use the same mounting holes and hardware? Thanks
Reason: forgot wording
Its very easy. You need to remove the bottom cusion of the jump seat and you will see 4 t55 torx bolts. Remove these and the jump seat is gone. Install the console with the same 4 bolts in the same place. Its a great mod, I love my center console.
ETA: The bolts are in VERY tight. You will need to use a breaker bar or something similar. An impact wrench would work great
My day begins when yours is about to end.
IN VINO VERITAS
Thanks man and there are a few on ebay that i saw here is one and they are a little hard to find for cheap but you can check your local junk yard and see if they have one but i got mine from ebay... here is one link http://cgi.ebay.com/ebaymotors/NEW-0...spagenameZWD1V
but i got mine from http://cgi.ebay.com/ebaymotors/2007-...spagenameZWDVW
but it has a number that you can call and see if they have anymore the number is 1-479-471-1835 .... good luck with your search
I never considered that swap, looks very good. If I ever see a gray one for a low price maybe i'll give a bid. I dont care console to jumpseat but it would look better. Jumpseat is a bit better for then I gotta clean the windshield though
