Seat Belt Retractor
Seat Belt Retractor
My 2001 Reg Cab drivers side seatbelt wont retract without me guiding it . It seems that the return spring is extremely weak. Has anyone else had this problem? Can it be serviced/fixed or does it need to be replaced? Is it possible to remove the plastic trim without breaking everything? So many questions, so little time!!
Rastatt
49.70' N
124.96'W
Rastatt
49.70' N
124.96'W
Well I cant say much about it but I actually have the same problems... but I find it weird it happening to you, as my truck is a 97. I hate it cause when you close the door I find it having to open again cause the seatbelt gets pinched on the door. I was thinking of replacing the whole thing but its kinda pricy.
Well, since I came to this section of the forum to ask about the same problem on my 2000 f-150, I guess I don't need to start a new thread. Mine does the same thing and was hoping to be able to tighten the retracting spring. It looks like there are two holes on the side of the retracting spool cover. Does anyone know if these have something to do with getting the cover off? As mentioned above, I may not be able to do anything, but I have nothing to loose. The belt gets caught in the door all the time if I don't guide it back. It rather bugs me, because the truck is 6 years old and this is the only thing wrong with it. It's showroom condition otherwise.
I dont mean to hijack this thread, but I have a big problem with my passenger
Seat Belt Retractor as well. Yesterday my Vegas change jar tipped over in the front seat and spilled over $100 in coin onto the floor by the door sill and into, yes into the retractor. Now the belt is stuck all the way out. I need to look more closely (when I am not so pissed off) but it looked as if access to the inside screws of the plastic cover is blocked and the seat needs to come out. Anyone know if this is the case? It also looked (in the dark, with a flashlight) like they are allen head screws. Anyone know the size?
Again, sorry for the hijack.
Thanks, Rod.
I think this is a standard feature of Ford. I've examined my driver side retractor and found no way to get into it without breaking something that appeared to be better left unbroken.
One thing I have seen, and have yet to try, is applying some polish onto the guide thing at the top (the part near your head). Lift the belt and apply polish to the bar that the belt slides over. It might help, or not, but I've searched for a year or two and this is the only "answer" I've found. Well, short of mortgaging my house to buy new belts that is.
