Review of 4x4TruckLEDS LED headlights
#31
Thanks,
Mike
#32
This photo above shows what they look like when installed upside down (the wrong way).
#33
Do yourself a favor... stop spamming your products on here this way. Just replying to threads that have nothing to do with your product. Every thread you replied to with your new account was the same, about that same amazon link you are sharing.
SPAMMER ALERT
SPAMMER ALERT
#37
so on leds how do you want the bulb positioned? horizontal or vertical ? maybe a pic of how bulb should look installed
#38
Diodes at 3 and 9 o'clock with the shield on the bottom facing up. This brand from 4x4truckleds should come positioned correctly out of the box with no adjustment needed. Their institutions might be backwards.
#39
#40
I can see better in my truck at night then al the other newer vehicles I drive.
#41
Hard to beat HIRs tho with PNP. 2300 lumens with HIRs. Granted the LEDs boast more. But retrofit would be the most output. But most expensive.
#42
They are OEM projectors. I think they're pretty good, but I'd love more light for sure. I have done research and Philips makes the only HIR2 now and it's the standard. It IS the only option from what I found. It's already the best of that, but I'd be curious to try these. I know they'd be an improvement in the truck, the my Taurus is the daily and I use the lights all the time. I've been thinking about a retrofit, but I'd like to try these I think since they're significantly cheaper and PNP. Looks like your brand is street glow and they do sell the 9012 on their website. $175
#44
Did you buy from 4x4truckleds?
Edit: I see you bought some cheap $30 eBay LEDs. I can't help you with those. But I'd recommend you return them and get a better set. The ones you bought don't have a cut off shield and are going to blind oncoming traffic.
#45
