Projector Retrofit
Old 01-20-2016, 06:41 PM
AndersonS's Avatar
Projector Retrofit
So, uhh... I'm about to order this kit. Am I going to regret it?
How should I spec the options for it?
- So far, I'm thinking: 50W ballast / Flat top Apollo 2.0 shrouds / 100mm XSB Halos / 5500K
What cosmetic changes to the housing do you think would look good?
Old 01-20-2016, 09:34 PM
thelariat02's Avatar
You won't regret it one bit. I'd go 35w tho. 50w can be a bit much when used for long periods of times driving down a long day highway. Straining on your eyes.
You are going to need to cut the reflector bowl with a3" hole saw to set these into your lights. Then epoxy to mount them.
Old 01-20-2016, 10:25 PM
FXR is a great choice. Very similar/competitive with RX350
35w is plenty of light with the right color
Old 01-21-2016, 04:14 AM
AndersonS's Avatar
Ordered!
I wasn't paying attention and accidentally bought the 50W ballast option. The price was the same, so I didn't notice. I think I'm going to roll with it tho. Hopefully they're not too bright.
I'm gonna hack up these headlight assemblies and paint the reflectors satin black. I'm not sure how I want to handle the turn signal housing tho. I was thinking all black and leaving the reflector bowl chromed.
Old 01-23-2016, 11:11 PM
AndersonS's Avatar
Tennessee "snowpocalypse" delayed my shipment until possibly Monday.
Old 01-24-2016, 10:01 PM
thenewbreed's Avatar
Same setup I have. The 50W burnt out the Stock harness plug on mine. I ended up going back to 35W. Not as bright but the 35W is still brighter and better than stock halogens by far.
Old 01-24-2016, 11:24 PM
Projector Retrofit
That's why you run a relay harness.
Old 01-24-2016, 11:28 PM
Get your information straight before you post. This is not a PNP HID system..
THIS IS WHAT I HAD WHEN THE 50W BURNT THE SOCKET
Old 01-24-2016, 11:52 PM
Projector Retrofit
Then it wasn't the 50w that killed your stock plug. It was a fault in the relay. Your stock plug is just a trigger for the relay.
Unless you had the canbus system which doesn't use a relay. In that case I would be wrong.
Old 01-24-2016, 11:57 PM
That's probably better information, but when I was going through the issue TRS suggested going to 35W. So that's what I ended up doing. I replaced the system with a new harness and D2S 35W morimoto ballasts.
Old 01-24-2016, 11:59 PM
You have a 2012 right? So that "should" be a H13 canbus system in which case ya the 50w would have killed it.
Old 01-25-2016, 10:48 AM
AndersonS's Avatar
Running the 9007 Motocontrol, I think...
Old 01-25-2016, 06:17 PM
AndersonS's Avatar
Mother of God...
And I couldn't help myself here.
Old 01-31-2016, 12:16 AM
AndersonS's Avatar
Well... Here's one of em...
Old 02-09-2016, 03:24 PM
ak_cowboy's Avatar
Cutoff look really good
Quick Reply: Projector Retrofit
