97 F150 4x4 Depo Headlight Upgrade Install w/ Pics
After much consultation from fellow forum members i decided to go with:
http://www.ebay.com/itm/Depo-Pair-Euro-Style-Black-Projector-Headlights-W-Corner-Lights-Ford-F150-F250-/301091174010?pt=Motors_Car_Truck_Parts_Accessories&hash=item461a6eb67a&vxp=mtr
In the time it took to grill the steaks I was able to get one headlight in, temporary install on the wiring though.
I was not aware that the Headlights came with bulbs. They came with a Standard Sylvania 9007 in the reflector and a Philips 9005 in the projector.
I already had a Phillips 9011 so i replaced the projector with the 9011. I do not have the GE NightHawk Platinums yet so i left the standard 9007 in the reflector.
During Installation of these lights it is necessary to notch the panel for clearance of the bulb in the projector lens. Quick and easy modification. Here are a couple pictures of what you have to cut out.
If i were to do it again i believe i would make the notch a little taller by taking more off the top side. This would allow you to be able to remove the harness without having to take the headlight out.
Before Notch:
After Notching:
I realize i didn't do a very clean job. But i was running out of daylight. I sanded and rounded all edges to protect wiring.
Here are some pics I snaped last night comparing the Aged Factory Lenses to the New Depos. Notice the new Depo headlight just has a standard bulb where as the factory headlight has the X-Treme Power.
Driver Side:
And the finished product, never mind the weeds hanging from the bumper. My truck gets well used. LOL
- Main Reflector - GE NightHawk Platinum 9007 Hi/Low Beam.
- Projector - Phillips 9011 Hi Beam
Before Notch:
After Notching:
Driver Side:
- Headlight Assymbly: Depo Black Projector
- Low Beam Reflector: 9007 Standard Sylvania
- High Beam Reflector: 9007 Standard Sylvania
- High Beam Projector: 9011 Philips
- Headlight: Aged Factory
- Low Beams: Burt Out
- High Beams: 9007 Phillips X-treme Power
Also hope you are happy with your purchase. I know I loved the high beams on them when I had them.
I definitely love the high beams! I still have the Sylvania 9007 bulb in the reflector. It is not as bright as i would like for the low beams. I think i will be putting nighthawk platinum in soon.
Another thing to note about the low beams are that the beam isnt uniform. it has bright spots and dim spots. The bright spots do seem to be where you would want them to be. But the dim spots take some getting used to.
Proper relay wiring harnesses:
http://www.theretrofitsource.com/com...harnesses.html
And how they are used:
http://www.theretrofitsource.com/diy...ess-guide.html
So - Where is Depo's documentation? Where is their Tech Support?
Sadly - you are now experiencing the consequences of buying junk....
Good luck.
PS - PM Karl65 fer more info ... Depo expert
While I appreciate the links, it doesn't really do much for me as far as my current situation is concerned. I have a truck with no headlight relay since it uses a multifunction switch. I was asking about Lariat's install because I am assuming he ran into the same situation. I am by no means an automotive electrician but a fairly able DIY guy just looking to see if there is a viable solution to my current situation. If the Depo lights don't work, I'll return them and do something else.
When I bought my depo lights they came with the relay, but this was 2-3 years ago.
