You can go with the Sylvania SilverStar mini bulbs ( they have stop/turn/tail and reverse version ).
They are a little bit brighter.
Thing is, how do you define "a little more light" ?
I would say the lumen output from the stock 3156 to the 3156 Silverstar Mini is about an additional 194 bulb worth of lumen, to give you an idea that you can stick a flag in the ground on.
If you have a 194 bulb socket you can temp tag this onto the reverse circuit and hang it next to the reverse lamp area of the tail lamp housing. If you can do this, check if this is enough little more light to see if it is worth it.
Don't bother installing a halogen 3156 bulb, these are generally 50W, and the DTR ( Digital Transmission Range ) Sensor will not take the additional load on the switch, the bulb will not burn at full brightness.
