08-03-2011, 12:19 AM
2004 Ford F-150
Vehicle: 2004 Ford F150
Light Bar and Switch Panel Install
So I just finished installing a Randy Ellis Designs light bar and two pair of Hellas (500ff and 700ff driving lights) on my 2004 FX4 screw. I fabbed up a custom switch panel in the cubby beneath the pull out cupholder in the dash and installed some aircraft style safety toggles. Here are the build photos and some brief captions:
Here is the "Pre" photo. As you can see, the previous owner installed two PIAA fogs in the gap in the bumper.
I chose the Randy Ellis Designs light bar because I liked the 1-3/4" tubing and it also happened to mount in between the existing PIAA fogs without alteration.
Painted the hardware for the Hellas.
Lights mounted.
The wiring under the hood is pretty basic so I will skip that. I mounted the relays near the firewall on the passenger side in case you are wondering. So, now, here is the switch panel which I am quite proud of. I started by removing the empty (and useless might I add) cubby beneath the pull out cupholder. I slotted the top of it with a dremel to make room for a piece of 1/8" ABS textured plastic which would make the front of my switch panel. I also cut a large portion out of the top in order to install the switches from the back.
Next I cut out the ABS face plate using a paper template and slid it in through the top, trimming to fit.
Next, I drilled the holes for the switches, and test fitted the switches. When I was comfortable with the fit, I made some gussets and used a plastic epoxy to tie everything together.
Finally, I wired the relay leads to the switches and then from the switch to an empty port on the fuse box which only operates when the ignition is on (no dead battery if the lights are left on without the key in). I tied the existing PIAA fogs into the switch panel as well. So, three of the switches are used: PIAA 510 fogs, Hella 500ff's, and Hella 700ff's (one dummy switch for future use just because I felt like it). I am super happy with it, it looks pretty professional and is not too obnoxious like some of the bright LED switches out there.
You all know how hard it is to do lights justice in a picture but here it is anyway...
08-03-2011, 04:50 PM
2006 Ford F-150
Vehicle: 2006 Ford F150
That is nice bro!!
I switches looks VERY clean. I wish I had one of those cubby's.
How do you like the 700ff's?
With all those lights on the front, should seem like daylight!!
08-03-2011, 06:21 PM
1998 Ford F-150
Vehicle: 1998 Ford F-150
 You'll hardly see those kind of switches in any small aircraft. More like military safety switches for missiles or something. You did great with that install! Looks very clean and looks like you have a lot of light. Any pics of the wiring?
-Alex
4.2L V6 - M5OD ~275K miles | SCT XCal3 | K&N Series-77 | 16" Dual Efans | Magnaflow High-Flows
50W 5000K FX-R Projectors | Philips LumiLED Taillights | 60" Plasmaglow Fire & Ice | 2" Drop Shackles
08-04-2011, 03:47 PM
2005 Ford F-150
Vehicle: 2005 Ford F150
Nice work, I used the same place for my switches when I did my light bar last year. I just used industrial grade toggle switches.
08-04-2011, 03:54 PM
2006 Ford F-150
haha I love your switches. freakin sweet. It looks like they are more for oil slick, missiles and smoke screen lol
14"Magnapack, Y-pipe, 2 4x18 45'd tips
http://www.youtube.com/watch?v=K2Zfpd66360&hd=1
6" skyjacker lift, 1" daystar spacer, 35x12.5 nitto trails and 17x9 black rhino sidewinders
Gotts mod, Platinum Burners series motorcycle headlights under the rear bumper.
08-04-2011, 03:58 PM
Looks good. I had a bunch of lights like that on my ranger (actually 10 after market forward facing lights) and had a switch for them. I got really tired of reaching down to turn off the brights when i a car came around the corner. With my F150 I just wired them to my stock brights with a relay so they come on with the stock brights. So much simpler and I find that I use them more often because of the convenience factor. Your install looks very good though.
2004 Lariat Screw. Leveled, 33" Toyo M/Ts on 20s, Pioneer F700BT, 110V outlet, OBA, rear air bags & semi horns, Gott's, Hella driving lights behind grill. Dual Dayton OH 10s getting 1000W in a ported box paired with amped Pioneer TS-D6802Rs.
The old: 2004 Ranger FX4, 4" SL W/ Fox C/Os, 3" BL 35s, 4.88s, Home made bumpers & headache rack etc.
The toy: 2006 WR450F
08-04-2011, 04:57 PM
2004 Ford F-150
That install is nice and clean. Got any pics of the output of all those lights?
 2004 F150 Supercrew Lariat 4x4
5.4L
20" Pro Comps with 33s
Aries Brush Guard with PIAA 540s
08-04-2011, 05:44 PM
how are the piaa lights mounted in the gap in the bumper?
08-04-2011, 05:52 PM
2005 Ford F-150
Very nice looking lights and switch panel!! If I ever need or want to add more switches, I will definitely put them in the cubby like that!
2005 Silver 4x2 Supercab XLT 5.4
285/70/17 Cooper Discoverer AT3, 2" Autospring Level
20% Tint on Front Windows
55 Watt Driving Lights in Lower Grille
100 Watt Long Range Lights Behind Grille
Cobra 29LX CB with 4' Wilson Antennas
08-04-2011, 10:23 PM
2004 Ford F-150
Poolboy......the output of the 700ff's is about the same as the 500ff's but I really like the way the different sizes look on the bar.
Raptor....Don't have any great pics of the wiring right now, I will try to take some this weekend. It is all pretty tucked away but I'll see what I can do.
Watson....looks like we have similar tastes. Props on the light bar, I wish I had the tools to fab stuff like that on my own.
atr04screw.......haven't had a chance to get the truck out of the city yet and check out the light output. I'll take some pics when I do.
Dave0....the PIAA's on the bumper are mounted right to the bumper in that gap. Drilling was required. (previous owner did those...and did a good job)
08-05-2011, 09:59 AM
any chance you have pics of the mounting job he did? i have an extra set of piaa lights from my ranger that id like to mount in a location like that.
08-06-2011, 03:55 PM
2006 Ford F-150
wherd you get the switch panel and those safety covers
08-06-2011, 08:59 PM
2004 Ford F-150
Quote:
Got the 1/8" ABS textured plastic on Amazon for like $15. Safety Toggles at pep boys for $8 each. Switch panel took me about 8 hours all said and done, getting it to fit just perfect in that cubby takes time.
08-06-2011, 09:14 PM
2004 Ford F-150
Here are some wiring pics:
Here is where I tied into the fuse box...
Here is where the switch wires from the fuse box and firewall enter the dash to the switch panel. You can also see where they run behin the dash to get across to the fuse box on the passenger side.
The inline fuses for the switches tucked up under the dash but still accessible....
Here is where the wires come through the fire wall on the driver's side and then head up into existing wire tunnel just below the windshield...
Wires come out of the wire tunnel behind the battery. One of the relays is also tucked in behind the battery, too hidden for a good picture...
Other relay mounted to firewall ground...
Connecting the lights to the positive battery terminal. You can also see the PIAA fog relay tucked away to the left if you look close (previous owner install)...
Here is the total view, pretty tucked away for the most part. I'll probably get some more plastic tubing for the red power leads, I don't like the way they catch your eye...
Here is the wiring up front by the lights, the blue connectors are the grounds for each light, bolted to the frame. Then all the wires run off to the left toward the battery. I used rubber heat shrink wiring tubing up front for protection, although I didnt actually shrink it with a heat gun, didn't feel the need.
ENJOY! I AM!
08-06-2011, 09:16 PM
2004 Ford F-150
Dave0,
here is a pic of the PIAA's on the bumper. Just a hole in the bumper.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
