2001 F250 AC not blowing cold
Old 07-26-2016, 09:39 PM
Fence Guy's Avatar
The issue started a couple years ago. It would blow cold for a little while and then blow hot. After a little while it would blow cold for a little bit and then hot again. I do not use the truck much so didnt really do much with it. Today I bought a can of AV pro to try and get it going as now its nothing but hot air. I put the gauge on it as per the directions. The gauge reads like 120psi and should be in the 35-55psi range according to the directions. This is all, while the clutch is not turning. I can turn the clutch by hand while motor is off. When I unplug the compressor and put a meter to the jack I get 12V and all fuses are good and I swapped relays so thats not it. Getting voltage at the compressor confirms that. I stopped trying to add gas and wondering if I should try again as the ACPro says try adding half a can to see if clutch starts to spin. Any ideas?
Thank you!
Bill
Old 07-26-2016, 10:00 PM
projectSHO89's Avatar
See HVAC FAQs....
Old 07-28-2016, 11:25 PM
Fence Guy's Avatar
Didn't help
Old 07-29-2016, 07:47 AM
Doh! My fault, they're on sister website.
http://www.ford-trucks.com/forums/75...xpedition.html
Old 08-01-2016, 01:36 AM
Fence Guy's Avatar
Thank you, I appreciate it. I'll try what they say there as long as I can find the switches they are talking about,lol.
Quick Reply: 2001 F250 AC not blowing cold
