Air Conditioner Compressor wont stop.
my 2003 F150's Air Conditioner Compressor will not stop running unless you put it on vent. is this normal? i think the compressor is suppose to turn off then come back on. is that true? mine just stays running non stop unless its on vent or turned off. or below the shutoff temp for the compressor. the air at the vent says about 42 degrees if it is 70 degrees outside and has been running for about 20 minutes the drain is plugged and the evaporator needs cleaned ( sand or something comes from the carpet when i sweep up the pooled up water in the passenger floor board. ) that is after cleaning the inside of the shopvac before using it and i have weathertechs so its not from my feet. just thought id throw that in just incase it could have something to do with it. the compressor was replaced in 2013 with a cheap one from speedway autoparts ( it is fairly loud ) it had oil put in it and 3 or 4 cans of R134a put in it ( just to hold it until i could get it professionally charged ) then one of the o-rings went bad and it all leaked out and i was without Air conditioning for about a year and a half. i had to use the defrosters a few times without refrigerant ( or very little ) in the system... it was vacuumed down and recharged professionally last summer. the compressor did the exact thing until i unhooked the battery to clean the mass airflow sensor. any ideas? the truck has the electronic climate if that matters. The truck said it was 67 degrees outside in this video.
the truck has the electronic climate control if that matters
well. It's to show what the compressor sounds like. An YouTube was the only thing I know how to upload videos / sound clips onto. But i will try to put gauges on it tomorrow. Thank you for the help. I'll post a photo of the readings from the gauges.
on
It's the LOW pressure switch that's supposed to cause the compressor to cycle. If the high side switch is causing it to cycle, the system has a very serious failure that's causing excessive head pressure.
It is completely normal for the compressor to operate in all settings except OFF, VENT, and FLOOR for a manual system. For an EATC system, it's a bit different, consult your owner's manual.
