Knocking sound when AC is engagued
Can you please help me diagnose this? My AC Compressor makes a chattering noise when engaged. I am trying to figure out if this is a clutch replacement or the whole compressor.
I took this video it it helps"
I will not be running the compressor as a precaution. Any suggestions are greatly appreciated!
Quick update. I took the belt off and the AC pulley spins freely with no side to side play. I can turn the outer clutch by hand and the compressor turns by hand..
I took it to a local mechanic I found on Craigslist, and he thinks the AC compressor is starved of oil and on in the early stages of going out...
I did find a lose idler pulley, it is the grooved idler pulley, but when I listen to the noise it sounds like it is coming from the compressor..
I might see if I can find an automotive stethoscope to pinpoint the noise more precisely... Is there anything i can do in a last ditch effort to see if it is the clutch before I have my mechanic replace the whole AC system??
