AC Problem
AC Problem
I had the entire compressor and clutch replaced because the AC quit. The coil did not work, so rather than going though the trouble of installing the coil, i had the entire unit changed. It worked fine when driving it home from the shop, however now it quit working. The charge appears good as i tried to jump the pressure switch and nothing came on. I understand the rear backup lights are on the same circuit and they work so it is not a fuse.
This is a new unit so the air gap should be good, and it did work on the way home. It will go back to the shop when I can get another car for work
Anyone have any suggestions?
