Go Back   F150online Forums > Body > HVAC
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 01-07-2011, 01:07 AM
Garage is empty, add now
Question A/C Compressor dead. smaller belt or bypass pulley?
I have a 1997 F150 Lariat with 5.4l V-8 and was told the A/C compressor is broken and has been somehow disconnected so if i select A/C from the dash, it won't be engaged. The actual compressor is still installed with the serpentine belt spinning it and i think the bearing in it is starting to go bad.
I've scoured these forums for a cheap solution (I don't need A/C) and it looks like i can either use a serpentine belt from a non A/C model truck (79.75 inches instead of 99.3 w/AC) or install an AC bypass pulley. The shorter belt seems much easier/faster/cheaper but from the belt routing diagram, it looks like the AC pulley has to be completely removed. Could somebody school me on what they would do in my situation? I don't need AC and want to keep the cost down.
Thanks much!
Old 01-07-2011, 05:55 PM
Vehicle: 2001 Ford F250 6.8
You will need both the bypass pulley and the shorter belt.
By that time, you could have already replaced the pulley and keep your current belt instead of castrating the system.
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX - Gone
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L - Gone
1998 Ford Contour Wifey's old daily driver, now mine.
2007 Mercury Mariner AWD - Wifey's newdaily driver
Old 01-10-2011, 12:40 AM
From the diagram on the shroud it looks like the short belt and no A/C Compressor would work fine. Where would the bypass pulley go if i need both the short belt and the pulley? Thanks for the help.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
