Old 04-13-2015, 05:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
Heater core replacement! Step by step with pictures
http://www.f150online.com/forums/hva...-pictures.html
ISSUE
Step-by-step instructions for Do-It-Yourselfers for how to replace heater core
Read below for the full discussion…
Print Wikipost
Old 10-10-2009, 02:40 PM
wutagoalie's Avatar
Hello all, thanks to everyone that helped me out with a previous post on "How to replace your heater core" This might come in handy this winter . This post has not only "black and white" pictures, but actual digital pictures as well. This was a great help, made things very simple! Enjoy
http://nator.net/files/Heater Core Replacement.doc
Old 10-19-2009, 11:53 PM
craignardo's Avatar
i used these instructions today, had whole job done in about 5 hrs, awesome step by step instructions
Old 10-27-2009, 10:18 PM
wutagoalie's Avatar
I'm glad they worked for you. Good job!
Old 12-30-2009, 05:28 PM
wutagoalie's Avatar
just thought id send this back, i am no mechanic, but i followed these step by step instructions with actual digital pictures of all steps, It was a breeze.
enjoy
Old 01-13-2010, 09:09 AM
MrTruck352's Avatar
Great job and article. What type of foam tape did you use on the core?
In my 1999 F150 repair manual it states to squeeze the plastic tabs to release the hoses on the firewall side, did your year require a tool for that?
Thanks again for the great article and pictures.
Forgot to mention I'm originally from Buffalo now living in FL, but not to warm this winter so far!
Old 02-28-2010, 02:52 PM
wutagoalie's Avatar
Actually the foam i used was given to me from the dealership. Im not sure if it was the right one, but it worked. as long as one side is sticky and the other is not, probably 1/4 inch thick. Looks like something used to seal a door, almost like a weather stripping.
In order to squeeze the tabs, you need the special tool. But because i planned to replace the heater hoses, I just chopped off the inlet and outlet ports right off the old heater core on the cabin side of the firewall.
Old 03-07-2010, 09:15 AM
ishootstuff's Avatar
Great document, thanks for the contribution. I will be using it soon as my heater core started leaking on a long trip yesterday.
On step 10, that's not the diagnostics port. That's an aftermarket anti-theft device called pro-lock (now out of business). Some dealers installed it when the vehicle comes in, then if you don't purchase, they put a blank in the contact slot to bypass it.
Upadte: I'm half way through the job and this guide is fantastic! Thank you! There were 2 screws on the very top of the dash under two covers that pop off near the windshield that were not listed, but again - THANKS!
Old 03-15-2010, 08:46 PM
rkd's Avatar
rkd
rkd is offline
This is a good writeup. Need to do this.
Can someone give me a part number or description for the heater hose disconnect tool?
Old 03-20-2010, 07:17 AM
wutagoalie's Avatar
I hear ya, i forgot to add those two screws in, when you get to that point, its fairly simple to realize the dash is being held up in that area. I will try and add that in. Thanks:
Old 03-20-2010, 10:41 AM
feddeytx's Avatar
one more question
First and foremost THANKS for the info! I will be starting this job this week.
I am stuck on the foam thing. I want to have all the parts before I start. Did the dealer include that when you bought the new core? You think regular weather stripping will work(have that, I am a Handyman). Did you replace the O-rings with new from the dealer or can I use the old ones? I will be doing a new radiator and water pump along with this.
Mark
Old 03-20-2010, 03:47 PM
wutagoalie's Avatar
The foam tape i got by fluke, when i was at Ford buying my heater core one of the mechanics walked by and over heard me asking the parts guys for this foam tape. The parts guy had no idea what i was talking about, the tape was not showing up in the parts list. The mechanic went to the garage and got me some of the stuff they use. The original foam that i took off was about 2" wide. the stuff he gave me was 1" wide, so all i did was placed 2 stips side by side. I never knew what the stuff was until at i saw it at an auto store. Its weather stripping for cars, used for doors and other areas. You could use
house weather stripping as well. Its a strip of foam with one side being sticky. Stick it all the way around the outside of the heater core.
As for the o-rings, i changed my 2 heater hoses as i did not have the special tool to remove the old ones, so i had to cut them off. When i purchased the hoses for Ford, they came with new o-rings and clips installed, all one peice, cost a bit more but all brand new parts and just had to clip in the new hoses to the new heater core.
Old 01-23-2011, 11:56 AM
henry68gomez's Avatar
where can i find these instruction on how to remove the dash to replace the heater core?
Old 01-24-2011, 01:32 AM
ktmracer26's Avatar
henry68gomez here is the link
Old 01-24-2011, 04:15 AM
craignardo's Avatar
if u use disposable plastic cups instead of baggies u can just number and stack the cups with screws in them, then they are already in the right order to put everything back together
Old 02-20-2011, 09:39 AM
wutagoalie's Avatar
There's a link on my first post above ??????
Quick Reply: Heater core replacement! Step by step with pictures
