A can of refrigerant will solve your short term problem, but you have a leak somewhere. Just add a 12 oz can with some dye in it(no Oil).
Look also for places on your refrigerant lines that have oil on them, and don't forget to look at the condenser also.
The low pressure switch is what causes the cycling of the compressor like that, it has nothing to do with the clutch itself at this point.
Your low side pressure should run about 35 pound of pressure at about 1800 rpm. If it is cycling on and off with a low of 20# at idle, you may need two cans of refrigerant.
