The condenser is in front of the radiator. It certainly isn't leaking.
Your evaporator drain is clogged. You have to get underneath the truck and find the drain. It will be near the base of the firewall and will likely be above the exhaust.
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
