EATC Issues - F150online Forums
EATC Issues
Old 07-07-2009, 12:09 PM
EATC Issues
2003 F-150 King Ranch
Background:
I can only get the air to blow through defrost on all settings except Vent.
Defrost, Def/Floor, Floor/Vent all blow through Defrost vent only.
With the setting on Vent, it blows through the vent.
A/C and A/C Max works.
What I did last winter was to move the vacuum tubes downstream of the EATC so that when I have the control on Vent, it blows a mixture of Defrost and Floor. That worked OK for last winter, but I would like to have it functioning properly - although I don't really want to spend $600 for a replacement!
I have good vacuum on the downstream side of the controller, so I assume I have a good vacuum feed to the EATC.
Does this sound like a problem that could be cured by the O ring rebuild referenced in another thread, or is the EATC pooched?
One other question.
It drives me nuts that the A/C will turn on automatically to adjust the temperature in the truck. I would like to have control of that feature.
Can someone tell me which colored wire coming out of the EATC turns the compressor on and off?
I would like to put a toggle switch in line on that wire
Old 08-04-2009, 06:34 PM
Quote:
Background:
One other question.
Bump.
From the other o-ring re-build thread our sysmptoms are exactly the same.
However mine seems to be a bit intermittent as i can sometimes get the AC to blow through the vents if i'm in "vent" mode and then hit "auto" w/ the fan set to low/medium not full blast
I have yet to look for under-hood vac line issues but i hope it's something that does not require me to tear apart the entire dash
Related Topics
Thread
Forum
Replies
Last Post
violator80
01-30-2016 02:09 AM
VAmountainman
Transmissions
9
09-18-2015 04:34 PM
tmgoethe
Illumination & Lighting
5
09-17-2015 09:00 PM
KwitcherBitchin
09-14-2015 07:17 PM
folmonty
SYNC System
2
09-10-2015 01:51 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
