F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > HVAC
Thread Tools Display Modes
Old 06-28-2009, 12:33 PM
AC compressor clutch screw size
Hello, I have a 2004 F150 FX4 since the beginning of the warm season my ac has not been functional. I finally had some time to check it out today and i noticed that a round metal piece had fallen off of something in the engine bay. I searched online and found it to be the ac compressor clutch.
I put the clutch on the compressor without bolting it down and I GOT COLD AIR. I was pretty relived i found the problem
Now i have to find the screw that holds it down because it wasn't on the clutch. So I am making this thread to ask what size the screw is and how long it is so I can enjoy some cold air while driving.
Below is the part I found circled in red. Its the one with three round pieces that look like a triforce. I need the screw that goes in the middle that secures it to the ac compressor.
Old 06-28-2009, 08:50 PM
Vehicle: 1997 Ford F150 5.4
M8 x 25 mm for the bolt. Common hardware store item.
You'll also probably need the shim that goes between the clutch plate and the pulley. Basically a thin washer of a thickness I've never measured or seen posted. Your Ford parts dept can probably get you one if needed.
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
Old 06-28-2009, 10:45 PM
Great. Thanks for the info about the screw. Would I need a washer for it? a locking one or plain one?
How would I know if I need the shim? How many does it need? Could you possibly post a picture?
Thanks again.
Old 06-29-2009, 03:24 AM
Vehicle: 1989 ford F150 4x4
here are the ford part numbers for the bolt and the shims.
19D648 -- A/C clutch hub spacer
N805332-S58-- A/C clutch bolt
you need to check the air gap between the pully and clutch. it should be (0.014-0.030in).
if the air gap is wrong, you need to remove the clutch and insert the shims at the bottom of clutch shaft, and if it hasnt fallen all the way out, the original shims should be in place still.
there is just a small flat washer inbetween the bolt and the compressor clutch.
almost forgot, the torque on the retaining bolt is 10ft lbs.
hope this helps
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
