F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > HVAC
Thread Tools Display Modes
Old 06-21-2009, 10:15 PM
a/c compressor inop. 2004 f-150
COMPRESSOR CLUTCH NOT COMMING ON.POWER GOING THRU LOW AND HIGH PRESSURE SWITCH'S.IF I JUMP POWER TO CLUTCH A/C WORKS FINE,READ SOMEWHERE THERE IS A MODULE ON PASSENGER SIDE KICK PANEL"HELP"TRUCK HAS AUTOMATIC TEMP. CONTROL SYSTEM
Old 06-22-2009, 08:55 AM
Vehicle: 1997 Ford F150 5.4
Pleas repair your CAPS LOCK key, it appears to be stuck on.
Check fuses F2.11, F2.14, F2.32, and the AC Clutch relay.
The fuses are in the box under the cover at the passenger side kick panel. See your owner's manual.
The relay is in the Auxiliary Relay Box #1 located under the hood on the driver's side fender.
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
Old 06-22-2009, 10:57 AM
Thanks for your response,will ck. fuses & relay today.Will let you know how I make out,Tom
Old 06-22-2009, 10:24 PM
Hi,checked fuses & replaced relay R202,still no power to compressor clutch.
Did not have a relay to try so purchased new relay.Went on a 30 mile trip today all highway and transmission went south,display showed transmission fault,o/d light flashing,will post on drive train cant catch a break......tom
Old 06-23-2009, 04:49 AM
Vehicle: 1981 ford bronco
If the refrigerant charge is low (due to a leak), the compressor won't come on. Possibly leaking out the seal on the front of the compressor.
Old 06-23-2009, 11:42 AM
With power jumped to compressor clutch & gauges hooked up ,gauge readings are normal.So i don't think its a freon issue.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
