F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > HVAC
Thread Tools Display Modes
Old 06-18-2009, 12:21 AM
Vehicle: 1999 Ford F150
AC cluctch wont kick on
hey iv tried playing around with my ac pump, but im usure how to test the clutch any ideas?
Old 06-18-2009, 09:15 AM
Vehicle: 1997 F150
#1 I would start by useing a test light, to see if electricity is gatting to the clutch.
#2 Hook gages up to the refridgerant line, just to see if there is any pressure in the syste.
#3 Look in the owners manual, to locate all fuses, and relays assosiated with the A/C.
Post up what you find, then we can go from there.
Old 06-23-2009, 09:01 PM
sorry its a 99 F150 4.6L v8, auto trans, 4x4
SO if thier is no preasure in the system< would that cause the clutch to not kick on?
Old 06-23-2009, 10:36 PM
Vehicle: 1997 F150
They have a low pressure and high pressure switches on them. But if there is no pressure the clutch will not engage. The low pressure switch is on the accumulator, mounted on the firewall. Make sure all the wires are connected.
Do you you have access to any manifold gages?
Old 06-24-2009, 09:50 PM
no i dont think i do, like to preasure check? i have no idea how ac systems work...
Old 06-24-2009, 10:59 PM
Vehicle: 2001 Ford F150
heres a quick test that you can do that can help me get you to the next step. If you look in through the passenger side front wheel well you should have a clear view of the the ac compressor/clutch (has 3 'nodes' on the front with a belt running around it but wont be spinning). With the truck running and the AC on, take a plastic handle screw driver or broom stick or something and just poke or tap and hit the face of the compressor. Let me know if it kicks on for a bit and cycles. If it does it will more than likely not stay running, but should kick on for an 8-15 second cycle.
Give that a shot and lemme know what you find and ill help you out once you share your results with
NO REGRETS!
Rockstars wrapped in Mickey Thompson ATZ's, Black L Headlights & Corners, Mangaflow exhaust, In-Dash DVD, 12" Infinity Perfect mounted downfiring in the center console, 1000w Kenwood amp, Kappas in the doors, T-Bars Cranked, All interior lights replaced with LEDs, Carbon Fiber Dash Kit, Gotts Intake, Tinted Tails
Old 06-25-2009, 10:06 PM
Hey so its working now, i got my buddy who does electronic diagnostics to play around with it, his OBD2 scanner showed the clutch was active and tested all the electrical terminals, they had power. we gave the clutch direct power and it didnt click in or out, so i gave it a wack with a deadblow hammer and then sicled the cluch in and out manually, its working so ill leave it for now i guess,
Thanks to all who helped with all their input!!!
Dan
Old 06-25-2009, 10:48 PM
Vehicle: 1997 Ford F150 5.4
Your clutch gap is excessive due to wear.
Remove a shim.
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
