F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > HVAC
Thread Tools Display Modes
Old 06-03-2009, 11:17 PM
Vehicle: 2000 Ford F150
dash duct damper gaskets?
2000 F-150 SCAB
I had the trim panel around the radio and heater controls off and noticed the foam gaskets around the dash ducts were falling apart. Bought some self-adhesive foam weatherstrip at Home Depot--problem solved.
Then I screwed up. The insides of the ducts looked nasty, so I disassembled and cleaned them. The gray foam gaskets around the edges of the dampers disintegrated when I got them wet. The foam is about 1/16" thick and flimsy as hell.
Where can I get replacement seals, or material to make them?
Old 06-04-2009, 09:45 AM
Vehicle: 2006 Ford F150
Send a message via AIM to Hawkz28
The foam in my 2006 F150 ducts jammed up my moade door. I got it out and wanted to replace the ripped up foam (probbaly similary to what your talking about). I went to the dealer to get a new piece and unfortuantely the foam is part of the next higher assembly, meaning you have to buy a $100 duct to get the foam!
I said no to that and I just improvised my own seal by using the felt side of velcro to make a seal. Umm, you could also try to use headliner foam and glue it on using spray adhesive, thats what I was going to do orignially but I couldn't access the ducting to spray on adhesive...........
Old 06-04-2009, 02:53 PM
Thanks for the suggestions. I think I'll check a fabric store and see if I can get felt that might work.
Now that I think about it, I can imagine my father cutting up one of his old felt hats for this. He was a great improviser: Joseph Philip Swan 1915-1995
Old 06-04-2009, 03:31 PM
when you get foam, make sure it doesn't hold moisture, you don't wan tmildew. I was going to use headliner foam because regular foam can get damp and mildew can grow in it..........
Old 06-19-2009, 06:45 PM
I found a solution to my problem--plastic craft foam sheets from the dollar store. For a buck, I got 10 8"X10" X 1.5mm sheets of foam in assorted colors. One was black, so I used it to make new gaskets. Worked like a charm.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
