F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > HVAC
Thread Tools Display Modes
Old 07-09-2007, 11:02 PM
134 won't charge any further
OK, got a gauge set with both high and low side gauges. I hooked them up and measured my low and high side pressures at about 50 and 90 respectively.
I added pressure until my low side read about 90, expecting the compressor to kick in and drop it, and for the high side to start going up to what it's supposed to be (around 250 in this heat).
It just stopped at about 90 low side and 95 high side and won't go up any more, and the compressor does not kick in to drop the low side.
The clutch it seems doesn't wanna kick in, I guess?
Any ideas what else might be wrong that I could try to fix it?
Some trouble shooting Ideas?
Rich
Old 07-10-2007, 03:12 AM
Vehicle: 1983 Ford Bronco
If you have 40psi difference with the compressor off, then you have SERIOUS problems in the A/C system.
But it sounds more like you didn't open the valves on the gauges (normal direction), or the ones on the ends of the hoses that connect to the fittings. Most hose valves have to be screwed IN to open (contra-intuitive).
Old 07-10-2007, 08:16 AM
Vehicle: 1997 Ford F150 5.4
The pressure inside a sealed sytem is the same everywhere when the compressor is not operating (given time to equalize). Any difference in readings has to be due to the gauges or measurement technique.
If you have 90 psi in the system but the clutch doesn't engage, you have either an electrical circuit fault or the clutch is bad (usually excessive air gap).
In order to further provide advice, you have to specifically identify your vehicle. There are differences in the circuitry over model years and sub-models.
Steve
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
Old 07-10-2007, 01:03 PM
electrical
fuse, clutch cycling switch, hi-pressure switch, etc is defective.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
