Sounds more like he's running it with BOTH manifold valves open.......
Static pressure must be the same on BOTH sides. That's why it's called the static pressure.
BTW, was this a set of cheap gauges from either interdynamics or Harbor freight? If so, that would explain a lot....
Steve
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
