03-13-2007, 01:09 AM
1997 Blend door actuator
1997 F150, just replaced heater core about a month ago, but now I don't have AC. I am assuming that the blend door acutator has gone bad. Does the dash have to come out to replace the actuator? or is there some other way to get to it?
03-13-2007, 07:48 AM
2003 Ford F-150
Vehicle: 03 4X4 5.4 SCREW
Yes, to get the actuator for the blend door out you have to pull the dash. Make sure its the actuator by pulling the black vent cover over the tranny hump and watching it when sending the command. If its a AC/ blend problem, its probably a broken door. Give us some more info on the AC problem; what its doing and not doing.
03-13-2007, 07:55 AM
I believe it does but not 100% sure. I am sure someone will verify. I did blend door and heater core in my 97 a couple months ago and now 1/2 wish i would have replaces motor at that time.
03-13-2007, 08:32 AM
Garage is empty, add now
Vehicle: 2001 Ford F250 6.8
A failed blend door will cause a loss of outlet temperature control regardless of the A/C.
If you can control the outlet temp in HEAT mode, then the blend door is not the problem, you should then be focusing on an A/C-specific problem.
Steve
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX - Gone
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L - Gone
1998 Ford Contour Wifey's old daily driver, now mine.
2007 Mercury Mariner AWD - Wifey's newdaily driver
03-13-2007, 03:44 PM
even on the highest setting for the AC I still get only heat. When I change the temp control from hot to cold or vice versa, I do not hear the door moving. Before I changed the heater core I could usually hear it a little bit. The guy at the ford dealer suggested that I change the actuator when I changed the heater core, but I didn't listen. I did however have to put a new blend door in because my old one was broken. I am assuming that it is the belnd door actuator, but any help would be appreciated
03-29-2007, 03:47 PM
ok now, I have the dash pulled and I am in the box where the heater core is located. I am trying to get to the blend door motor, but it is on the bottom of the heatercore housing box. I am stuck and don't know where to go from here. Do I have to take the entire housing out, which means unhooking the heater and evaporator core? If so how do I do this? I have been looking for screws or bolts or something, but I am completely lost. PLEASE HELP!!!
03-31-2007, 07:13 PM
I just have the same problem. But the blend door motor can be removed without taking the dash apart.
Remove the cover at the bottom uncovering the lower duct. use a fine hacksaw to cut the duct in half (drastic maybe). Remove an 8mm screw from the right hand side. Slide out the right half of the duct. Remove 3 8mm screws front the blend door motor. (small fingers needed) unplug and slide down and out the motor. use black duct tape to re-assemble the cut duct.
04-07-2007, 01:43 PM
Ain't life great!!! Installed the new blend door motor and it worked the door twice! Spent today installing a new blend door. Took 5 hours start to finish. Not bad for a first time. Bottom of the door had crumbled, so replacement was the only fix. Just watch out for hidden screws when you do this!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company |
