F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > HVAC
Thread Tools Display Modes
Old 09-12-2006, 08:26 AM
Climate Control - AC Is On By Default?
It's getting chilly in the mornings here in New England and I'm noticing that even when it's in the 40's, like this morning, the AC is on when I start the truck, climate control temp set to 68. Is this normal? I just manually shut off the AC but I'm wondering why the AC comes on by default when it's heat that I want.
Any ideas?
Old 09-12-2006, 08:53 AM
Vehicle: 2005 Ford F150
Even though the light is on, it should not be running the compressor if it is not needed. I would check to see if the compressor is engaged. The Auto function should make all those decisions for you based on the temp you select. This is how it was explained to me.
Old 09-12-2006, 09:12 AM
Thanks. I'll listen for the compressor to engage. I just see the 'AC' indicator on the display and assume it's on. It does go off when I hit the 'AC' button.
That makes sense though and I bet you're right.
Old 09-13-2006, 12:58 AM
If you're turning it on to either floor/defrost or full defrost, the AC compressor will turn on.
'05 F150 SuperCab XLT 5.4l
'05 VW Passat Variant TDI
'85 VW Vanagon GL
'75 VW Westfalia
'74 VW Super Beetle
Old 09-13-2006, 09:14 AM
Vehicle: 1997 Ford F150 5.4
Consult your owner's manual.
AC compressor operation is typically enabled in ALL climate control positions EXCEPT OFF, FLOOR, and VENT.
A lot depends on what year you have and whether you have a manual or automatic climate control, information you did not provide.
In any event, RTFM...
Steve
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
