Old 04-13-2015, 01:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Blend door replacement with pictures
http://www.f150online.com/forums/hva...-pictures.html
ISSUE
’97-’02 F150’s and Expygators temperature blend doors are breaking. This is a labor intensive Do-It-Yourself guide with pictures and details
Read below for the full discussion…
Print Wikipost
Old 12-08-2014, 01:56 PM
Backnblack_66's Avatar
Originally Posted by mitzo
These warranty are such rip offs.
Only if you buy them without reading them....
  #62
Old 02-06-2015, 01:14 PM
Jakepayne99's Avatar
  #63
Old 02-25-2015, 01:30 AM
disguy21's Avatar
Help HVAC heater blend door 98 f150
Originally Posted by Jakepayne99
So what happens if i just take out my blend door completely will just get hot air or cold air only?
  #64
Old 03-02-2015, 06:29 AM
You wont get hot or cold air w/o the door.
  #65
Old 03-02-2015, 06:36 AM
Originally Posted by Paradisd
What an incredible write up! Thanks so much for taking the time. Now I see why the cheapest place I've found to replace the heater core wants $800 to do it. I have always hated doing heater cores, but I think this quite possibly may be the worst I'll ever attempt. I think I had less aggrivation replacing the motor in my 98 Cobra than I'm going to have replacing this heater core I had flushed the system with water and tried some of that stop a leak crap, but I couldn't tell if it worked. The leak seems to be rather small, the level in the radiator overflow doesn't go down and there is no fluid on the carpet. I see now how I was able to still smell antifreeze with the A.C. on with that huge enclosure for the 2 cores.
One question I do have, I was told this 99 Navigator had 2 heater cores, where is the second?
Me doit for 300..
Quick Reply: Blend door replacement with pictures
