Go Back   F150online Forums > Body > HVAC
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 03-21-2004, 07:44 AM
Garage is empty, add now
Vehicle: 1999 Ford F150
A/C Cool Problem
Recharged my A/C on 1999 F150 Super Cab with 5.4 engine. At startup and low speeds A/C works fine. At higher speeds and after engine warms up, no cooling. Has full charge and no leaks that I can find. Any ideas?
Old 03-23-2004, 01:23 PM
Vehicle: 2001 Ford F250 6.8
Check for evaporator icing.
After how long of a period of operation does the failure occur?
Steve
Old 03-23-2004, 09:40 PM
I THINK SYSTEM IS NOT CHARGED PROPERLY. ON AUTOMOTIVE A/C I PREFER TO WEIGH REFRIGERANT IN. TAG UNDER HOOD OR ON RECIEVER TELL YOU EXACTLY HOW MUCH. BUT I HAVE AN ELECTRONIC SCALE TO USE. CHARGING BY PRESSURE IS GUESSWORK. DID YOU RUN ENGINE AT 1,500 RPM WHILE CHARGING ? IF NOT TRY THAT AND CHECK YOUR GAUGES, I THINK YOU WILL FIND YOU ARE LOW ON REFRIGERANT.
Old 03-23-2004, 10:46 PM
Vehicle: 2003 Ford F150
Also make sure you have a high volume fan blowing into the condensor coil up front
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
