Go Back   F150online Forums > Body > HVAC
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 03-19-2004, 10:30 AM
Garage is empty, add now
Vehicle: 1997 Ford Expedition
suggestions for tracking a leak
Every 3 weeks I am charging 12 ounces of r134 to my system and I can't find the leak; where should I be looking for?
regards,
Marcos
got two consoles in my expedition (97)
Old 03-21-2004, 12:21 AM
Vehicle: 03 Ford f150
Send a message via AIM to Pestco1
One of the easiest ways is to look for oil. Oil leaks out of the system with the freon. If the hoses in the engine compartment are oily clean them with brake cleaner, then keep an eye on them for the next few days. Other methods include using dye in the next freon charge and looking for the leak with a blacklight. You might also be able to find an electronic leak detector that someone will loan or rent to you. I would concentrate on the fittings, both behind the compressor and at the connections for the other components. They use the same high pressure fitting that is used on the fuel system. Sometimes the o rings crack and you can get a leak this way.
Old 03-23-2004, 09:24 PM
Vehicle: 1998 Ford F150
the most common place for leaks on these a/c systems is the front compressor seal. Take off the small 8mm bolt on the front of the compressor, take off the clutch and look inside where the shaft is. More than likely it will be wet in there. Good luck.
Bottles are for Babies.
Real men get blown!
'98 supercab XLT.
2001 Lightning drivetrain conversion. 6lb lower pulley. JLP ram air intake box. Roush classic chrome wheels, FT valve body, Precision Industries 2400 stall convertor, Mark VIII electric cooling fan modified to fit in the factory shroud. Lightning front end, Harley headlights, Snug Top hard tonneau cover. Bedrug. Lighted tailgate Ford emblem, Flamed billet rear view mirror. Ported Eaton, Accufab throttle body, Ported upper and lower intake manifolds. Phenolic upper intake spacer, C&L intake tube, C&L 95mm MAF, Aux. idler for blower,etc. etc. etc..............
Old 04-02-2004, 08:54 AM
Vehicle: 1987 Ford F-150
I use the UV dye.it works great.I am a professional A/C tech,on commercial,& residental systems,but they make the UV dye for 134a for automotive use.you gan get it at autozone or wal-mart.they make a special Uv light,but you can just use a normal black light to look for the leak one night.
Old 04-10-2004, 04:22 PM
Vehicle: 1999 Ford F-150
one good source of a cheap blacklight is the blue LED stylus streamlight penlight.
I too am a certified HVAC and for $20 or less on a blacklight that can get into many places a big bulky blacklight can't you might want to investigate the stylus if you need an affordable blacklight.
Remember, the blue LED model is the one.
FordMasterTech
Technical Consultant
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
