Go Back   F150online Forums > Body > HVAC
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 01-02-2004, 06:59 PM
Garage is empty, add now
Vehicle: 1998 Ford F150
Question 98 F-150 heater core connections
Well, I've got a core that's leaking big time...can anyone describe how to disconnect these so-called quick-connect hoses? I've started the job, but am already stymied. There's not much room to work...can I just pull the thing thru from the inside, then separate the hoses? Any help is greatly appreciated.
Alan
Old 01-02-2004, 11:02 PM
Vehicle: 2012 Ford F150
The hoses have quick-disconnect type fittings. If you look at them closely you will see two tabs sticking out from each fitting, 180 degrees apart. You have to squeeze these to release the fitting. While squeezing thes, you might try pushing on the hose a little. Good luck and hope you have small hands.
Old 01-03-2004, 07:13 AM
Thanks for the info
I'm back on it...thanks for the info.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
