Go Back   F150online Forums > Body > HVAC
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 11-18-2003, 08:21 AM
Garage is empty, add now
Vehicle: 1997 Ford F150
Question 1997 Blend Door
I have a 1997 F150 supercab. I keep blowing Fuse # 5 15amp to the A/C clutch, Cruise control, Back up lights and Climate blend doors. When I replace the fuse, it blows as soon as I turn the key to the on position. I have unplugged everything except the blend door actuator and the fuse still blows. I have read alot about blend doors sticking and how to replace and fix the problem. No-one has mentioned blowing fuses. Is this a common problem?
This is a quote from one of the places I have searched.
"Just got my truck back from the dealer for this problem. They told me that the actuator and heat box (where blend doors are) have to both be replaced...now get this....
Parts and labour!! = $1583.00 "
Any suggestions? I am going to try and tackle this problem this weekend.
Thanks for any suggestions.
Old 11-18-2003, 10:24 PM
Just a thought here. I know when my cruise control went bad it also affected the HVAC system, not sure which fuse or amp. Turns out it was the speed control sensor on the front of the master cylinder. It would blow the fuse as soon as the key was turned on unless the HVAC was set to off and then it would blow as soon as I tried to set the cruise.
Old 10-24-2006, 02:21 PM
Vehicle: 1999 svt
I know this is old but I am having #5 blow as well. any more ideas? I traced the blue w pink stripe wire (from back of fuse box on #5)to the climate control. I unplugged it but it still blows. It may T off somewhere but I can't find a schematic.
Old 10-25-2006, 12:08 AM
Vehicle: 1999 svt
fixed. Harness over on passenger side was touching headers
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
