Go Back   F150online Forums > Body > HVAC
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 06-25-2003, 12:00 AM
Garage is empty, add now
Vehicle: 1999 Ford F150
Question A/C stops on acceleration
I recently bought a used F150 supercab XLT 4x4 automatic with 5.4 I tested the a/c before I bought and felt satisfied that it was in good working order. Fan works, Max a/c works, heater and defroster works. I towed a small boat last week through the desert in 95 degree heat and noticed that the fan would stop blowing out the main vents as I accelerated and under a load uphill but on deacceleration or down hill the fan would blow cold air at full force. The defroster vents seemed to blow at a constant speed regardless of the main vents blowing or not. I know this can't be right! Has anyone had this problem and / or have any solutions or suggestions? Your help and advice would be appreciated.
Old 06-25-2003, 07:52 PM
Vehicle: 2003 Ford F150
behind the battery theres a small vacume hose from the engine to the firewall check to see if it doesnt have a leak
Old 07-24-2003, 12:49 AM
Vehicle: 1994 ford f150
I've got a 94 f150 4x4 302 AT and the same thing is happening to me. Since I don't see any real obvious vacuum lines behind the battery on this rig, I suspect that what I need to look for is a vacuum leak of some kind. I'll do that, but now I'm curious. Why is a vacuum leak causing the fan motor to cut out? I can understand the flappers in the heater box moving around, but that would/should only give me cold defrost (if that's the default position). Right?
Or is the AC actually hooked into the brain somehow and so responds to the load that is on the motor?
Old 07-28-2003, 09:57 AM
Vehicle: 2007 Ford F150
Don’t know if this helps with your situtation but the compressor will shut down when your at WOT (wide open throttle).
Old 07-29-2003, 11:28 PM
2001 Ford F-150
Vehicle: 2001 Ford F150
Here's some info.
Vacuum Reservoir is popping
Your vacuum will drop with an increase in rpm. If you have a leak, you may not have enough reserve to prevent the airflow diverter from defaulting to defrost.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
