Go Back   F150online Forums > Body > HVAC
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 03-12-2003, 07:17 AM
Garage is empty, add now
Vehicle: 1997 Ford F-150
Heater Core
My carpet is wet at various times on the passenger side UNDER THE MAT. I figure this is my heater core, although i dont know much about this particular part of the truck. What Blows my mind is have made a routine to figure out the source of the water/moisture. I is only under the floor mat, the carpet is wet, but when i pull the carpet up, the floor pan is dry and not rusted. I run my hands all up around the dashboard and anywhere i can guess i leaks from. I need to find a way to trace this water b/c I think there is a possibility it may be coming from some loose body bolt from my body lift and water is entering. SO.... if the heater core is bad and or leaking ... should water ever collect on top of the mat? Or maybe should it run down the carpet from an exact location. Whoa..What an long and boring topic..I just hope someone has some input on this b/c i would hate my floor pan to rust.
PICTURES HERE
http://www.f150online.com/galleries/...y.cfm?gnum=190
*White 97 F-150 Supercab 2WD
*4.6L Triton V8
*4.56 Gears with Tru-Trac Limited Slip
*Lariat Seats
*AIM 3" Spindle Lift
*Fabtech 2" Leveling Kit with Fabtech A-Arms.
*Fabtech shocks
*3"rear blocks + Add-a-Leafs
*SuperLift 3 inch BodyLift
*315/75/16 Procomp Allterrians
*American Racing AR136 16x8
*Flow Master 50 series 4" Tips
*Rhino Liner
*K&N Filter
*Smitty Built Chrome Brush Guard
*Smitty Built Crome Nerf Bars
*Magellan GPS-3 Navigation
*Wind Visors and Bug Deflector
*Alpine Deck, Punch Amp
*12'' Solobaric L7 Custom Box
*2 Procomp Stainless Steel 130watt lights
WISH LIST:
*MUCH BETTER BRAKES*
Old 03-31-2003, 07:44 AM
Vehicle: 1997 Ford F150
Hmm...well, I can tell you this much. When the heater core went on my previous truck (A Chevy), it was very obvious that the heater core was at fault. There was coolant on my passenger side floor and that distinct smell. If all you're getting is water with no sign and/or scent of coolant, I doubt that your heater core is the problem. Honestly, it sounds like you may just have a piece of bad weather stripping that is letting water leak into your truck. I'd look into that first, maybe pour some water down from the top of your windshield and then take a close look at where the water was previously inside the truck. Good luck, hopefully it isn't the heater core!
Old 03-31-2003, 10:30 PM
Vehicle: 2003 Ford F150
Been running your a/c lately? that could be your source...find where the tube comes out of the firewall on the passenger side and give it a good flik with your finger and see if water doesnt start coming out of it,,,flik it a few more times to make sure it clears
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
