F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Audio & Video System > Head Units
Thread Tools Display Modes
Old 06-29-2009, 12:30 AM
Talking Pioneer 3100 and the reverse cam
I thought I'd post this as a topic, instead of buried in another thread.
After playing around with my 3100 today, I finally got the reverse camera working, and it did NOT require the reverse lead on the HU. I simply wired up the video in, and powered the camera. If you go to the system menu you can set up the camera input (I don't know the difference between the battery and ground mode), and on the main source menu there is a button for Rev Cam in the upper right corner, next to ESC. Click that button, and the camera should click on. If you touch the screen, you will return to the active source, however after about 7 seconds the camera image will return. To disable the camera, go back to the main menu and click the Rev Cam again.
Doing it this way will not tell the HU to flip to the camera when you shift into reverse, but it makes the install all that much easier. Plus, you can always try to track the wire down later.
Enjoy!
Old 06-29-2009, 05:04 PM
OK, slight update. I think i figured out the battery and ground settings for the camera. When set to battery, the HU requires a current to indicate the car is NOT in reverse. In other words, if you select battery, unless you provide a current to the reverse indicator, the camera will not shut off. Even worse, it will hold your screen hostage.
Without hooking the reverse indicator to anything, ground seems to work as I stated above. I haven't bothered to ground it, it's just taped off.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
