Black/Pink wire for reverse camera? WTF!
On my 2005 that could be the cigar lighter or either of the two power points. All three of these are on when the ignition is in acc or on position and turn off when the ignition turns off.
There should also be several other power sources available at the fuse box.
Thanks to Low E Red for pointing out that black/pink wire for reverse.
Just connect the camera's power lead to any 12 volt source that is switched on/off through the ignition switch.
help!
Thanks for the replies.
I found it! Went out this morning and looked at the bundle of wires again, and there it was. I couldn't see very well last night due to lighting conditions. It looked like the wire had a violet stripe (still does, really).
I tested it to make sure it came on when in reverse and off again when not.
Here it is with my wire attached.
blk/pink wire
I found it in my 97 lariat just over the emergency brake pedd. I used a voltage tester,peirced it as i moved to reverse,to verify it was the correct wire. Maybe i got lucky,but i just had to cut a little tape to lossen the bundle of wires enough to use a blue wire tapper to tie in the connection.
Hope this helps!
Hope this helps!
